Thread network recreated without resetting Google Play Services data
I think I managed to re-add devices into a new network, without resetting Google Play Services data (I didn’t lose any google wallet cards).
Unfortunately, I just tried a bunch of things and I’m not 100% certain which of the steps worked and which were unnecessary. Here is the rough order of steps that I’ve done.
  1. In Hass > Thread, I reset open thread border router. Made a new network as preferred, deleted old one, and clicked the button to “Use for Android + iOS credentials”
  2. I deleted the device that needs to be re-added in Hass. And also firmware reset the device.
  3. I found on Android phone an area where all matter devices and thread networks are stored. In Android settings, open Google > “All services” > “Matter devices” (there were also at times drop down in top right corner showing different grouping of devices). I deleted all those devices.
  4. I tried few times clicking in Hass Android companion app on “Send credentials to Home Assistant” button (in Settings > Thread) and on “Sync Thread credentials” (in Settings > Companion App > Troubleshooting)
  5. Also, in Settings > Google > “All services” > “Thread networks” I found my existing thread network. I think I noticed that once I reset the otbr in Hass, this area shows available networks with the new identifier, but it had subtitle as “unavailable” or “not configured” at first. After clicking on “Sync Thread credentials” in companion app, this subtitle disappeared and it looks like android phone now had credentials for this network. Additionally, in network preferences, I disable credential synchronization with the cloud.
  6. Throughout this process I also installed and uninstalled Google Home app.
  7. If I tried to add a thread device at this point, then the device would get added and connected to the phone, (the network id showing up on the phone would properly match the current on in hass) the device does get added to the phone and stored, but then when I attempt to add the device to Hass, it would fail after a couple of minutes of attempting.
  8. I restarted otbr container and matter server container. Somehow matter server restart got stuck and I had to restart the node running this matter server. (I suspect this might have affected IPv6 addresses, so maybe this was needed :person_shrugging:)
  9. I also restarted android phone (I suspect this might have also affected IPv6 addresses caches or something :person_shrugging:)
  10. After all of these, when in hass companion app I click on the button to “Sync Thread credentials”, I consistently get a message “Updated network from Home Assistant on this device” and when I click “Send credentials to Home Assistant” it says “You don’t have any credentials to import”.
  11. After all of these, I added a device like normal, and it got successfully added to Android phone, it had a matching thread network id to my current one in Hass, and then the device got successfully added into Hass as well.
I’m sorry for the wall of text, I was just trying to record all the things that I tried. I hope this helps somebody in the future, or it will kick off another round of investigation. :person_shrugging:
Not sure, but perhaps it was this uninstalling/reinstalling Google Home app that may have been the trick to clear out the Thread credentials from the Google Play Services indirectly
Good news for all! I’ve reproduced it on my device where I’ve been struggling also. I couldn’t remove the ghost credentials of an old Matter/Thread network hosted by a Google TV Streamer and my phone couldn’t see the new one hosted by the ZBT-2. When trying to sync on my phone I would get the “Devices preffered network is different than Home Assistants” message.
  1. I uninstalled the Google Home app from my phone, immediately re-installed it.
  2. Then went into Home Assistant companion app settings, troubleshooting, Sync Thread Credentials. Now it finally showed the “Added network” message.
  3. From there I still couldn’t see the ZBT-2’s Thread Network in the android settings yet, but scanned I scanned the devices QR code to add it to a network, and from there it displayed that it was connecting to the ZBT-2’s thread network name and connected like you would expect (after I installed the Matter Integration in HA).
(Note: I still can’t see the ZBT-2’s thread network inside my phones settings, but I can add devices to the network which is all I care about)
Thanks for the details all. Sadly, uninstalling and reinstalling the Google Home app still left me with the wrong Thread network. I really don't want to reset Google Play Services since my WearOS device relies on it for connection and reconnecting that takes literal hours to set back up.
FWIW, I was able to remove the thread credentials with my rooted phone. Thank goodness for options for control over your own device! Apple ruined so much about computing...
ANYWAY, here's what I did:
  1. On my rooted Android 11 phone, turned on Airplane mode to kill internet connection for Google Play Services
  2. Force-stopped Google Play Services
  3. Used the app Amaze Browser (a file manager for root, any root file manager should work) to navigate to /data/data/com.google.android.gms/
  4. Backed up and deleted the following files: thread_border_agent_database-shm and thread_border_agent_database-wal and thread_border_agent_database
  5. Turned internet connections back on
  6. In the Home Assistant Companion App, went to Settings > Companion App > Troubleshooting > Sync Thread credentials
  7. Added a new Matter device
At that point, HA went through the usual Google Matter overlay and this time detected the correct Thread network. It took a couple of minutes, but it did add the device.
This seems to be the key point. On my new Samsung Galaxy S26+, that was all I had to do to get the Thread credentials added to the phone.
Trust me when I say this alone is rarely the fix. It’s the first thing any of us do when we have this problem. All this does is pull whatever is stored in Google Play Services. It can’t replace it.
  1. Backed up and deleted the following files: thread_border_agent_database-shm and thread_border_agent_database-wal and thread_border_agent_database
This is the true fix.
Unfortunately, rooting my phone is no option, it’s Enterprise managed, my IT Department will kill me… Had the hope that they fixed it in Android 17 but it looks that it’s still the same…
We should all go and upvote this one: [Thread] Allow users to change the Preferred Thread Network and select the Thread network for Matter commissioning [564071942] - Issue Tracker
That’s a great ticket, +1’d
