Threading.py error - simple tasks like check config/restart are not working
Some integrations are working but simple stuff like restart/check config loop continuously (loading circle)
This is what I get on startup
2022-01-20 13:24:46 ERROR (Thread-2) [root] Uncaught thread exception
File "/usr/local/lib/python3.9/threading.py", line 973, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.9/threading.py", line 910, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.9/logging/handlers.py", line 1518, in _monitor
self.handle(record)
File "/usr/local/lib/python3.9/logging/handlers.py", line 1499, in handle
handler.handle(record)
File "/usr/local/lib/python3.9/logging/__init__.py", line 952, in handle
self.emit(record)
File "/usr/src/homeassistant/homeassistant/components/system_log/__init__.py", line 192, in emit
entry = LogEntry(record, stack, _figure_out_source(record, stack, self.hass))
File "/usr/src/homeassistant/homeassistant/components/system_log/__init__.py", line 103, in __init__
self.exception = "".join(traceback.format_exception(*record.exc_info))
File "/usr/local/lib/python3.9/traceback.py", line 120, in format_exception
return list(TracebackException(
File "/usr/local/lib/python3.9/traceback.py", line 533, in __init__
self._load_lines()
File "/usr/local/lib/python3.9/traceback.py", line 545, in _load_lines
self.__context__._load_lines()
File "/usr/local/lib/python3.9/traceback.py", line 543, in _load_lines
frame.line
File "/usr/local/lib/python3.9/traceback.py", line 288, in line
self._line = linecache.getline(self.filename, self.lineno).strip()
File "/usr/local/lib/python3.9/linecache.py", line 30, in getline
lines = getlines(filename, module_globals)
File "/usr/local/lib/python3.9/linecache.py", line 46, in getlines
return updatecache(filename, module_globals)
File "/usr/local/lib/python3.9/linecache.py", line 137, in updatecache
lines = fp.readlines()
File "/usr/local/lib/python3.9/codecs.py", line 322, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x8a in position 3096: invalid start byte
