Three MQTT panes are missing on "overview" window
After one of the last two updates three MQTT sensor panes are missing on my “overview” window.
Also, after rebooting, I am getting warnings in the log file.
Any ideas??
Keith
System Log
19-01-16 15:18:52 INFO (MainThread) [main] Initialize Hass.io setup
19-01-16 15:18:53 INFO (MainThread) [main] Setup HassIO
19-01-16 15:18:53 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 142
19-01-16 15:18:53 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-01-16 15:18:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-01-16 15:18:53 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-01-16 15:18:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-01-16 15:18:53 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-01-16 15:18:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: de.pengutronix.rauc - /
19-01-16 15:18:53 INFO (MainThread) [hassio.host.info] Update local host information
19-01-16 15:18:53 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-01-16 15:18:54 INFO (MainThread) [hassio.host.services] Update service information
19-01-16 15:18:54 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-01-16 15:18:54 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {‘hassio-supervisor’}
19-01-16 15:18:54 INFO (MainThread) [hassio.host.services] Reload local service hassos-apparmor.service
19-01-16 15:18:54 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-01-16 15:18:54 INFO (MainThread) [hassio.hassos] Detect HassOS 1.10 on host system
19-01-16 15:18:54 INFO (SyncWorker_1) [hassio.docker.hassos_cli] Found HassOS CLI homeassistant/armhf-hassio-cli with version 8
19-01-16 15:18:54 INFO (SyncWorker_0) [hassio.docker.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.85.1
19-01-16 15:18:55 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/core repository
19-01-16 15:18:55 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
19-01-16 15:18:56 INFO (MainThread) [hassio.addons] Load add-ons: 52 all - 52 new - 0 remove
19-01-16 15:18:56 INFO (SyncWorker_2) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-configurator with version 2
19-01-16 15:18:56 INFO (SyncWorker_7) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-mosquitto with version 4
19-01-16 15:18:56 INFO (SyncWorker_3) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-samba with version 8
19-01-16 15:18:56 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-duckdns with version 1.5
19-01-16 15:18:56 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-01-16 15:18:57 INFO (MainThread) [hassio.snapshots] Found 2 snapshot files
19-01-16 15:18:57 INFO (MainThread) [hassio.discovery] Load 1 messages
19-01-16 15:18:57 INFO (MainThread) [main] Run Hass.io
19-01-16 15:18:57 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-01-16 15:18:57 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-01-16 15:18:57 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
19-01-16 15:18:57 INFO (MainThread) [hassio.addons] Startup system run 1 add-ons
19-01-16 15:18:57 WARNING (MainThread) [hassio.addons.validate] Unknown options plain
19-01-16 15:18:57 WARNING (MainThread) [hassio.addons.validate] Unknown options plain_websockets
19-01-16 15:18:57 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-01-16 15:18:57 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl_websockets
19-01-16 15:19:00 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-mosquitto with version 4
19-01-16 15:19:01 INFO (MainThread) [hassio.services.mqtt] Set core_mosquitto as service provider for mqtt
19-01-16 15:19:01 INFO (MainThread) [hassio.discovery] Duplicate discovery message from core_mosquitto
19-01-16 15:19:05 INFO (MainThread) [hassio.addons] Startup services run 2 add-ons
19-01-16 15:19:06 WARNING (MainThread) [hassio.addons.validate] Unknown options name
19-01-16 15:19:06 WARNING (MainThread) [hassio.addons.validate] Unknown options guest
19-01-16 15:19:06 WARNING (MainThread) [hassio.addons.validate] Unknown options map
19-01-16 15:19:07 INFO (SyncWorker_8) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-samba with version 8
19-01-16 15:19:09 INFO (SyncWorker_0) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-duckdns with version 1.5
19-01-16 15:19:16 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.85.1
19-01-16 15:20:07 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-01-16 15:20:07 INFO (MainThread) [hassio.addons] Startup application run 1 add-ons
19-01-16 15:20:11 INFO (SyncWorker_6) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-configurator with version 2
19-01-16 15:20:16 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-01-16 15:20:16 INFO (MainThread) [hassio.core] Hass.io is up and running
I just noticed that all three room sensor boards states are unknown in Services under Developers Tools.
don’t worry about warnings, worry about errors.
Sensors don’t show up as services. Suggest you look at the dev-state page.
Thanks about the warnings vs. errors…
I see the sensor (temp/humidity/pressure) state values changing using the Dev. States but the panels are not visible on the overview page. A buddy of mine also has missing panels since one of the recent updates as well.
Are you using chrome? If so is the problem still present in Firefox?
Hi Nick,
Yes. I’ve used chrome for over a year now with no issues.
I’ve tried ie and firefox… same result.
Personally, I think it’s the UI since many of us are missing panels.
Keith
