Three-position switch with "ON," "OFF," and "AUTO"
I would like to submit a request for the implementation of a three-position switch with “ON,” “OFF,” and “AUTO”
Is this about having a backend mechanism to achieve this (like using an input select as Wally has suggested) or also the frontend side of having an intuitive UI widget for this? Any suggestions based on your expectations of how something like this should look like?
You could create a slider (input number) with 3 values?
PS: don’t forget to vote for your own request :wink:
Thank you for your responses. To clarify, my request pertains to the UI component. I’m looking for an intuitive UI widget that can easily represent and control the three states: “ON,” “OFF,” and “AUTO.” Something like below, but I’m not a graphic designer :slight_smile:
onOffAuto
Why don’t you use buttons for that?
You can apply the mode code to your buttons
