Hi
I am trying to setup a threshold binary sensor and receive the error below on startup. I am running 34.3 so the version is okay.
Error:
16-12-06 13:33:04 homeassistant.loader: Unable to find component sensor.threshold
16-12-06 13:33:04 homeassistant.bootstrap: Unable to find platform sensor.threshold
Here is the config for sensor in question:
platform: threshold
threshold: 100
type: upper
entity_id: sensor.aeotec_zw096_smart_switch_6_power_58_8
The entity_id IS valid. I’d like to use this threshold sensor for dryer instead of having to do something complicated, to see when dryer is done.
When I look at States here is what I see for that entity_id:
sensor_class: power
node_id: 58
unit_of_measurement: W
friendly_name: Office TV
Power icon: mdi:speedometer
fabaff
(Fabian Affolter)
December 6, 2016, 8:57pm
2
keith-michael:
It’s a binary sensor. The sample in the docs was recently updated.
Yes! This corrected the problem, thank you. I see the document has been updated to reflect the correction. In case anyone searches for this problem and has it (you shouldn’t since doc is updated) here is my updated config:
binary_sensor:
platform: threshold
threshold: 100
type: upper
I am having the same issue, but using the correct syntax…
17-04-16 06:48:52 ERROR (MainThread) [homeassistant.loader] Unable to find component binary_sensor.threshold
17-04-16 06:48:52 ERROR (MainThread) [homeassistant.bootstrap] Unable to find platform binary_sensor.threshold
Any ideas?
still getting these errors while ive set the sensors up according to the documentation:
2018-01-17 07:58:06 ERROR (MainThread) [homeassistant.config] Invalid config for [binary_sensor.threshold]: required key not provided @ data[‘threshold’]. Got None
required key not provided @ data[‘type’]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/binary_sensor.threshold/
changed the sensors to the syntax you use here and now error in the logs are gone and sensors show up fine.
Documentation should be updated … though it does seem more efficient to define the threshold binary_sensor as described on https://home-assistant.io/components/binary_sensor.threshold/
correct syntax:
- platform: threshold
name: "Wasmachine threshold"
entity_id: sensor.wasmachine_bijkeuken_actueel
type: upper
threshold: 4
name: "Droger threshold"
entity_id: sensor.wasdroger_bijkeuken_actueel
type: upper
threshold: 4
name: "Vaatwasser threshold"
entity_id: sensor.vaatwasser_keuken_actueel
type: upper
threshold: 4
documented syntax (not working resulting in errors)
upper: 4
upper: 4
upper: 4
theres no such thing as coincidence…
i created these threshold sensors at the exact moment the latest hassio update was rolled out, and now the original sensors i made are correct after all…
upper: 4
upper: 4
etc.
of course several other options available.
Documentation still could benefit from an update.
check: https://github.com/home-assistant/home-assistant/pull/11110 for specifics on the latest.
breaking changes in 0.61.1
threshold and template sensors (with some custom ui embellishments)
cheers,
Marius
