Threshold: Problem with own Implementation
As the Stock-Integration “threshold” does not allow to fetch the Values upper, lower and hysteresis from an input_number, I try to work on such a Solution, but run in to the Problem, that the Hysteresis does not work as expected.
What you will need:
The input_numbers to communicate with the Theshold:
input_number:
  th_test_probe:
    min: 0
    max: 100
  th_test_threshold:
    min: 0
    max: 100
  th_test_hysteresis:
    min: 0
    max: 10
A binary_sensor, which will reflect the current State. Choose one, depending if the Sensor should reflect “Probe is lower than Threshold” or “Probe is higher than Threshold”:
binary_sensor:
    sensors:
      th_test_too_low:
        unique_id: th_test_too_low
        value_template: >
          {% set current_state = states('binary_sensor.th_test_too_low') %}
          {% set probe = states('input_number.th_test_probe') | float %}
          {% set th = states('input_number.th_test_threshold') | float %}
          {% set hyst = states('input_number.th_test_hysteresis') | float %}
          {% set lower = th - hyst %}
          {% set upper = th + hyst %}
          {{ probe < upper if current_state else probe < lower }}
      th_test_too_high:
        unique_id: th_test_too_high
        value_template: >
          {% set current_state = states('binary_sensor.th_test_too_high') %}
          {{ probe > lower if current_state else probe > upper }}
In Lovelace you may create a Card to test the whole Thing:
type: entities
title: Threshold-Test
entities:
  - entity: input_number.th_test_threshold
  - entity: input_number.th_test_hysteresis
  - entity: input_number.th_test_probe
  - entity: binary_sensor.th_test_too_low
  - entity: binary_sensor.th_test_too_high
Screenshot from 2022-01-14 15-01-41
