Most gas boilers are run by a single room controller, and that one room decides for the whole home. Put it in the bathroom and the bedroom overheats; put it in the living room and the bathroom stays cold while the boiler already throttles back. Smart radiator valves don’t fix that, the boiler still only listens to the one room. Thriftherm is a custom integration that replaces the room controller over ebusd and heats by the demand of all rooms.
What it does
- Looks at every room (temperature sensor, smart valve or Better Thermostat) and sends the lowest flow temperature that the neediest room requires, via
SetModeonbai. - Blocks space heating (
disablehc) when no room needs heat. Hot water is untouched and keeps following the knob. - Learns a heating-curve correction per room from real heating runs.
- Safe by design: the knob stays the upper limit, and if Home Assistant stops, the boiler falls back to its own knob after 9–16 minutes. Only
SetModeis written, never installer parameters. - Starts in Observe only: it calculates and shows what it would do, with a reason for every decision, and sends nothing until you enable active control.
- Optional: a heat pump / air conditioner in heating mode (e.g. Midea PortaSplit) with a live COP vs. gas price comparison. Fully local, no cloud, no telemetry.
Boilers so far: atmoTEC plus VCW 194/4-5, atmoTEC pro VUW PL 240/3-3M, ecoTEC plus VCW AT 196/5-5 R2 and VCW DE 244/4-5-HL R1 in use by their owners. I’m looking for owners of other Vaillant (and related) boilers – running a few days in Observe only and sharing the ebusd definition already helps.
Install: HACS / Marketplace → search “Thriftherm”. Repo and docs (EN/DE): GitHub - alpha-uniform/thriftherm: Thriftherm: smart gas boiler control for Home Assistant. Demand- and weather-driven flow temperature via ebusd, room control with Better Thermostat, optional heat pump such as the Midea PortaSplit. · GitHub
Questions and boiler reports welcome here or as a GitHub issue.
