Hey,
so I’ve build a custom component on esphome that basically acts as a modbus proxy/“translator” from one device to two other devices (power meter → solar/car loading point).
It polls the power meter modbus every 1.5 seconds and then responds to other modbus devices, usually every ~2 seconds (when requesteed)
And it updates sensors every 15 seconds for the values to be available in HA (I don’t need that frequent data in HA, and since I’m using influxdb and a bit longer storage on mysql that default, I don’t want to flood that with data every 1.5s)
Now I have another piece of python code running on a raspberry in which I would like to access the data every 2s (not always, but for about 1 hour every other day or so). But not sure how to achieve that?
I could update the sensor refresh time to 2s, but then this would flood HA also, plus I only need this frequent data infrequently
I also thought about creating internal: true sensors with a hope that they might be available via REST Api /events endpoint through event source, but that does not seem to be the case
Is there some smart way to achieve what I’m looking for?
