Try to update to version 0.5
Tried the 0.5 but no difference.
Error code
Logger: tibber
Source: /usr/local/lib/python3.9/site-packages/tibber/init.py:109
First occurred: 17:05:28 (1 occurrences)
Last logged: 17:05:28
Timed out when connecting to Tibber
Or maybe I am doing something wrong? I have tried to restart a couple of times.
Works after the latest Home Assistant upgrade
My Tibber pulse stopped working yesterday sept 1st at 16.00 CEST.
I found this in the log:
Logger: tibber
Source: components/tibber/init.py:55
First occurred: 1 september 2022 20:05:32 (1 occurrences)
Last logged: 1 september 2022 20:05:32
Error connecting to Tibber, resp code: 429
Version information:
Home Assistant 2022.8.7 Supervisor 2022.08.5 Operating System 8.5 Frontend-version: 20220802.0 - latest
I restarted HA yesterday, but it did not help. Tibber pulse is connected to WiFi and has no apparent issues in the router.
Anyone else, or is it just me?
/Fumble
Another HA restart today, together with reconnecting the Tibber pulse to the energy meter, got it going again.
/Fumble
Dear forum,
The energy dashboard reports large energy jumps after restarts of HA. Of course, catchup jumps are natural, but this is out of proportion, messing up the statistics. As I am using the Tibber integration, I figure that is the first place to look. Anyone else seen this?
Actual meter reading:
Not sure if this is a bug in the energy dashboard or what’s going on.
Your thoughts would be much appreciated!
/Fumble
Do you use the statistics mentioned Tibber - Home Assistant?
tibber:energy_consumption_HOMEID
I am using this:
Is that the same thing?
/Fumble
No, you should select tibber:energy_consumption_HOMEID
Strange - there is no sensor by that name when searching. However, when leafing through the available sensors in the energy dashboard, there is one named “None consumption”, with sensor name per your description. Very odd.
The new sensor even fills in the missing information - great!
Thanks,
/Fumble
Hello Danielhiversen,
I occasionally have the problem that the price display is “distorted”.
Do you have an idea what that could be?
correct:
wrong:
Hello @Danielhiversen ,
I use the tibber_custom HACS integration in Homeassistant. I like it very much. Since Homeassistant Core update 2024.2.1 it does not longer work due to missing matplotlib i guess. Do you think there is a other possibility to get the data shown in plot? Thanks for your help.
have a look here. I changed to it…
Thank you for the hint. I was able to implement the chart with the help of Tibber API and APEX chart.
