I’m running hassio 115.6 with no 3rd party modifications on a Raspberry Pi 4.
While trying to integrate Tibber into my setup, I get the following error message:
Logger: homeassistant.components.sensor
Source: components/tibber/sensor.py:123
Integration: Sensor (documentation, issues)
First occurred: 08:15:29 (2 occurrences)
Last logged: 08:20:44
tibber: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 346, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 469, in async_device_update
await self.async_update() # type: ignore
File "/usr/src/homeassistant/homeassistant/components/tibber/sensor.py", line 123, in async_update
attrs = self._tibber_home.current_attributes()
File "/usr/local/lib/python3.8/site-packages/tibber/__init__.py", line 664, in current_attributes
in self.info["viewer"]["home"]["meteringPointData"]["gridCompany"].lower()
AttributeError: 'NoneType' object has no attribute 'lower'
This does not tell me much, so I’m a bit clueless.
I have already tried to issue a new token and recreate the integration - without any change to the result.
I’m a German Tibber customer without any smartmeter yet. So, I only get the standard Tibber prices so far. Could this be the source of the issue?
