Tibber integration randomly stop working
Hi.
I have been running Tibber Pulse for some time (without being a Tibber customer). Some weeks back the Tibber integration start randomly stopping without any alerts or notifications I can find. I expected it was my HA installation (ESXi version running on ESXi6) with to much “lab activity” testing, adding and removing stuff.
I setup a new instance of HA, added only Tibber and a 2-3 other devices, ESPHome with one unit (A ESP32 displaying the current energy (the Tibber Power entity from my home). This has been running for 3-4 days, and now I see this has also stopped/frozen.
Anyone seeing similar behavior and can help out?
Hi, I have the same problem. When the integration stops, the CPU usage increases dramaticly and stays high until i reboot my Raspberry Pi. Really annoying
I have the same annoying issue. I need to reload the integration for continued operation.
Same issue here. It works for less than a day and then all values freezes and I have to reload the integration.
I have the same issue, is anyone looking into this? <3
Same here :frowning:
Maybe you should report as a bug, if this is not already there:
Hi, I have exactly the same problem. Disable tibber and enable it again get it going again.
Any one that have a solution?
Exact same problem here too. Have to restart integration for the numbers to start flowing again. Is it possible to automate restart of integration as a temporary solution?
It is!
alias: Tibber Reload
  - platform: state
    entity_id:
      - sensor.power_your_home
    for:
      hours: 0
      minutes: 5
      seconds: 0
  - service: homeassistant.reload_config_entry
      entry_id: xxx
mode: single
The entry_id can be found in .storage/core.config_entries. This should reload when there is no change for 5 minutes (maybe a bit on the long side).
where do I have to add your short script in HA ??
It’s an automation buddy :relaxed:
Be sure to adjust the sensor name and the entry_id to your need.
I got it. Thanks.
I have to generated a new script because I got an error with your version.
sequence:
  - wait_for_trigger:
      - platform: state
        entity_id:
          - sensor.stromverbrauch
        for:
          hours: 0
          minutes: 5
          seconds: 0
      entry_id: 5ed4818ecea4f8ea3d00daxxxxxaxxxx
mode: single
icon: mdi:head-sync-outline
Hi everyone,
I use relading integrations in some occasions, but for tibber it doesn’t seem to work.
I get an error that it wasn’t able to unload the integration.
Any suggestion?
No one?
On the current HA 2025.5.2 I even can choose the integration to be reloaded from the UI without digging through the core.config_entry
But there is no Tibber in the dropdown:
Even getting the ID from the config file it does not work.
Why can’t I reload this integration?
EDIT:
I found the Integration (it has my name and is not to be found by “Tibber”)
Anyway, reloading it fails, because an unload is not working.
I guess this is related:
Tibber integration loses connection · Issue #145216 · home-assistant/core
