No I mean the one from tibber data, names are similar but not the same. The first one in this print screen is from core integration but the bottom one is from tibber data, that one has future prices as attribute.
Weird, I dont have those. Is it this integration you are using? Mine are called tibber_data and not tibber data.
Yes, thatâs the one. I believe they will show up only when adding this part (for optional extra sensors):
tibber_data:
email: Your email registered at Tibber
password: Your Tibber password
Now I got the sensors but with no values in them
Are you supposed to use quotes arround email and password like this?
tibber_data:
email: "Your email registered at Tibber"
password: "Your Tibber password"
I donât know really but I donât have quotes in my configuration.yaml for either email or password.
Maybe it just takes some time for it to fetch the data. I donât know how often it updates.
Good point. I will give it a day.
Still no data, I give up
A while ago I also got some issues to get future data, so Iâve created my own RESTful sensor to fetch this info directly from Tibber and they work quite fine.
Feel free to copy it:
Nice dashboard. But for some reason, the numbers are not correct. I take your code and take it whitout any adjustments. View below the results numbers on the right side. (Both examples are from this page).
And this is the data sensor data:
I think it is the setting of the decimal, but changing it does not give the solution.
Any ideas about what will go wrong?
Thanks!
I just posted my solution for creating a tibber price graph (including future) over here: Tibber - Schedul prices upcoming 24 hours prices! - #58 by BerriJ.
I totally lost track here.
Do I have to make an extra template sensor?
And from Tibber I got a sensor that shows me:
state_class: measurement
today: 0.2169, 0.2025, 0.1998, 0.1976, 0.2004, 0.2246, 0.2448, 0.2559, 0.3155, 0.2583, 0.259, 0.2576, 0.2574, 0.2561, 0.2546, 0.2541, 0.254, 0.2541, 0.2536, 0.2529, 0.2516, 0.2517, 0.2462, 0.2306
raw_today:
- time: â2023-08-21T00:00:00.000+02:00â
total: 0.2169
etc etc
tomorrow_valid: true
tomorrow: 0.2324, 0.2261, 0.2172, 0.217, 0.2241, 0.2286, 0.2416, 0.2477, 0.2564, 0.2558, 0.2638, 0.2568, 0.2562, 0.2566, 0.2555, 0.2532, 0.2552, 0.2534, 0.2494, 0.2491, 0.2489, 0.2493, 0.2506, 0.2448
raw_tomorrow:
- time: â2023-08-22T00:00:00.000+02:00â
total: 0.2324
etc etc
unit_of_measurement: NOK/kWh
And I got another sensor that shows me
app_nickname: Hjemme
grid_company: ********
estimated_annual_consumption: ******
price_level: NORMAL
max_price: 0.316
avg_price: 0.244
min_price: 0.198
off_peak_1: 0.218
peak: 0.261
off_peak_2: 0.245
icon: mdi:currency-usd
friendly_name: Electricity price Hjemme
And which sensor to use for consumption? Accumulated current hour or accumulated consumption (day)
About that Apex Chart:
Any way to make it show 2 decimals in the price?
The axes descriptions have them but when I hover on a graph I only get a single decimal and the price basically moves within by 0.1-0.3 at maxâŠ
Edit: Found it (after trying with tooltip options and original JS doc):
add float_precision: 2 to every series that shall be presented with 2 decimals
Hi all,
i followed the Steps, but the âSensorâ wonât show up. What have i done wrong?
Solved!!
Edit: Noob Error: It has to be put under sensor:
How do i fix the tooltip to be also 2 oder 3 deciamals instead of 1?
Edit:
Solved it again by myself by adding flating precision, see here:
Thx @Berry00 - any idea how to fix the float in X axis ?
Hey everbody,
I need your help. Can someone write me the sensor template which pulls only the max and min prices of today (and tomorrow if available) an store each of the for values in an separate sensor entitiy.
Tibber allows to pull these values via rest, but unfortunately, I cannot get it running.
Alternatively, how can I extract these values from the attributes of a sensor entitiy?
Thanks Marcel
Hi CommanderROR,
ĂŹâm planning on doing the same thing and I find your sensor âCharge_Requiredâ and âCharge_Required_Tomorrowâ interesting. Do you have more information and do you still use the sensors?
Best regards
I donât use Tibber anymore (have moved to Octopus Intelligent Go) but I still use the Charge Required templates. They are a way to calculate how much charge my battery needs. If you want more information I would be glad to help.
Hi Commander,
thanks for your reply!
Firstly, great.
Because in general from where sensor data are coming in is not really relevant.
In meantime i have use your idea to test a few things in my system.
With AVG price iâve set a âprice levelâ sensor to trigger forcible charge if no more PV is coming down and my battery is below 50% / 25% - between 50% and 100% only charge with 2500W.
Thats my current state.
Your both last sensors are calculating difference between ârest of today PVâ and current capacity of your battery, right?
Maybe you can report how good that sensors are working in an automation?
Because a lot of time is gone since your post in best case you can report if you change anything to improve issue? Or maybe there are no issues ![]()
I only need charging of my battery during winter months and to make it not soo much complicated my idea was to check for remaining PV today and then simply choose âprice levelâ very_cheap or super_cheap (very cheap was set from 12% below AVG today price in my case). If conditions are there battery will be loaded to 100%âŠ
Maybe you have tipps or notes to thoughtsâŠ
Greets Paul
P.S. funny that most of people in this thread are germans and discussing nevertheless in english⊠![]()
