Tibber - Set SoC of an "non integrated" EV in Home Assistant
I use Tibber as power company/buy/sell electricity from.
I also have an MG4 EV. The MG4 does not have an “Tibber Integration”, which means that every time I want to charge my MG4 at home, with my “Tibber Integrated” EV charger (Easee), I need to manually enter the SoC (state of charge) of the MG4 into the Tibber app.
I would much rather have HA do that form me :smiley:
I can read relevant data from MG/SAIC using the integration;
And I have the Home Assistant Tibber Integration installed.
- Now, do we have any geniuses in here that can poke around in the Tibber API and find out if I can change the SoC of a specified EV (we have two).
Use evcc.io
Tibber is controlling my Easee EV charger. So, I kind of need to get the SoC value into Tibber.
But evcc looks super cool!
I have the same issue with my 2016 Nissan Leaf.
@Goethe14 How would evcc.io help in this situation?
evcc was of no help for me too.
The following works for me. Please note that this is not the official API and you should behave with care! It may break at any point without notice and cannot expect any help.
configuration.yaml:
rest_command:
  tibber_login:
    url: "https://app.tibber.com/login.credentials"
    method: POST
    content_type: application/json
    payload: '{"email": "{{ email }}", "password": "{{ password }}"}'
  tibber_set_vehicle:
    url: "https://app.tibber.com/v4/gql"
    method: POST
    headers:
      Authorization: "Bearer {{ token }}"
    payload: >
      {"query":"mutation setVehicleSettings { me { setVehicleSettings(id:\"{{ vehicle_id }}\", homeId:\"{{ home_id }}\", settings:[{key:\"offline.vehicle.batteryLevel\", value: {{ value }} }]) { id } } }"}
scripts.yaml
push_to_tibber:
  alias: "Push value to Tibber"
  fields:
    value: {}
    vehicle_id: {}
    home_id: {}
  sequence:
    # Step 1: Login to Tibber API
    - service: rest_command.tibber_login
        email: !secret tibber_email
        password: !secret tibber_password
      response_variable: tibber_auth
    # Step 2: Use returned token to send mutation
    - service: rest_command.tibber_set_vehicle
        token: "{{ tibber_auth.content.token }}"
        vehicle_id: "{{ vehicle_id }}"
        home_id: "{{ home_id }}"
        value: "{{ value }}"
      response_variable: tibber_set # optional, for debugging only
automations.yaml (i configured it via the UI, hence the numeric id
- id: '1755891222498'
  alias: Kia Ladestand zu Tibber
  description: ''
  triggers:
  - entity_id: sensor.kia_soc
    trigger: state
  conditions:
  - condition: not
    conditions:
    - condition: state
      state: unavailable
  - condition: not
    conditions:
    - condition: state
      state: unknown
  actions:
  - data:
      value: '{{ states(''sensor.kia_soc'') }}'
      vehicle_id: 'VEHICLE-UUID'
      home_id: 'HOME-UUID'
    action: script.push_to_tibber
M8!
I have to try this out!!
This is like the exact thing I have asked Tibber devs to implement and document in their API Explorer
Thanks @jks!
Here’s a slightly modified version (homeId is no longer needed it seems) that also allows you to easily discover the right IDs:
configuration.yaml:
# Tibber app API
rest_command:
  tibber_login:
    method: POST
  tibber_get_ids:
    method: POST
    content_type: "application/json"
    headers:
    payload: '{"query": "{ me { homes { id electricVehicles { id name } } } }"}'
  tibber_set_vehicle:
    method: POST
    headers:
    payload: >
      {"query":"mutation setVehicleSettings { me { setVehicleSettings(id:\"{{ vehicle_id }}\", settings:[{key:\"offline.vehicle.batteryLevel\", value: {{ value }} }]) { id } } }"}
scripts.yaml:
push_soc_to_tibber:
  alias: "Push SoC to Tibber"
  fields:
    value:
      description: "The SoC percentage"
      example: "80"
    vehicle_id:
      description: "The UUID of your vehicle in Tibber"
      example: "12345678-abcd-1234-abcd-1234567890ab"
  sequence:
    - action: rest_command.tibber_login
    - action: rest_command.tibber_set_vehicle
discover_tibber_ids:
  alias: "Discover Tibber Home and Vehicle IDs"
  sequence:
    # 1. Login
      response_variable: login_res
    # 2. Get IDs
    - action: rest_command.tibber_get_ids
        token: "{{ login_res['content']['token'] }}"
      response_variable: id_res
    # 3. Create a Notification in the HA Sidebar
    - action: notify.persistent_notification
        title: "Tibber ID Discovery"
        message: >
          {% set homes = id_res['content']['data']['me']['homes'] %}
          {% for home in homes %}
            **Home ID:** `{{ home.id }}`
            **Vehicles:**
            {% for car in home.electricVehicles %}
              - {{ car.name }}: `{{ car.id }}`
            {% endfor %}
          {% endfor %}
There is a dedicated integration for this as well now: GitHub - Elibart-home/tibber_soc_updater: Deze custom component voor Home Assistant maakt directe verbinding met de Tibber GraphAPI mogelijk, specifiek gericht op het uitlezen en besturen van elektrische voertuigen. De integratie gebruikt directe authenticatie met je Tibber account, onafhankelijk van de officiële Tibber integratie.
This is great. Have anybody with two cars sharing a charger figured out how to update the active car on the charger? It should be possible with the same API, but I can’t even figure out how to list my chargers.
I found the query I needed by intercepting the network traffic from the app:
  query: `
    mutation SetVehicleChargerSettings($homeId: String!, $chargerId: String!, $settings: [SettingsItemInput!]) {
      me {
        home(id: $homeId) {
          setVehicleChargerSettings(id: $chargerId, homeId: $homeId, settings: $settings) {
            __typename
  variables: {
    homeId: {{ homeId }},
    chargerId: {{ chargerId }},
    settings: [
        key: "selectPreferredVehicle",
        value: {{ vehicleId }}
My case is that I have one Mustang Mach-e with Tibber integration, and one Nissan Leaf without Tibber integration. They are both set up with the same charger in Tibber.
When connecting the charger Tibber tries to guess which car is connected, but very often fails to select the correct one.
But by using Tibber’s own API I can actually very accurately detect which car is charging, as the battery percent of my Mustang will show as 0 when not connected and the correct percent when connected to the home charger.
I guess this is specific for the Ford integration, as they only send the data if the car is connected to a charger at the home address, so it’s complicated for Tibber to put this into their generic vehicle detection code.
