Ticker - reworked 2024
Here is my rework of Ticker made by dennisaion here. Since initially I had trouble running it and then running as I wanted, I’ve mixed the project with this demo + added some adjustments.
Now it looks like this:
For this to work, you need to install this HACS: GitHub - PiotrMachowski/lovelace-html-card: This card displays provided data as an HTML content of a card.
And here is the script:
type: custom:html-card
view_layout:
  position: main
content: |
  <div class="ticker-wrap">
    <div class="ticker">
      <span class="ticker__item">ABC</span>
      <span class="ticker__item">DEF</span>
      <span class="ticker__item">GHI</span>
      <span class="ticker__item">Sun elevation: [[sun.sun.attributes.elevation]]</span>
    </div>
  </div>
  <style>
    ha-card {
      height: 0px;
      visibility: hidden;
    @keyframes ticker {
      0% {
        transform: translate3d(0, 0, 0);
        visibility: visible;
      100% {
        transform: translate3d(-100%, 0, 0);
    .ticker-wrap {
      font-family: Zen Dots;
      font-size: 2.5rem;
      position: fixed;
      bottom: 0;
      left: 0;
      width: 100%;
      overflow: hidden;
      height: 3.5rem;
      background-color: rgba(255, 0, 0, 0.7);
      padding-left: 100%;
      box-sizing: content-box;
      .ticker {
        display: inline-block;
        height: 4rem;
        line-height: 4rem;
        white-space: nowrap;
        padding-right: 100%;
        animation-iteration-count: infinite;
        animation-timing-function: linear;
        animation-name: ticker;
        animation-duration: 7s;
        &__item {
          color: white;
    .ticker__item:before {
      content: " • ";
    .ticker__item:after {
      content: " • ";
      margin-right: 40px;
  </style>
Tested with 2024 Firefox (macOS) and Chromium browser (running on RPi), HA: v2024.2.5, html-card 2024.03.24.
Was looking for something like this, and seems to work ok…
But next question, maybe a stupid one, is how to put in items depending on some states?
as an example i tried this…but it just shows me the complet if text in the ticker…
      {% if states.sun.sun.attributes.elevation > 0 %}
          <span class="ticker__item">Sun elevation: {{ states.sun.sun.attributes.elevation }}</span>
     {% endif %}
    </div>
  </div>
