When you cant get fourheat module with HA to work, somewhere above are comprehensive instructions how to connect NG21 with esp module.
I did look at my papers for my own stove and noticed that for NG21 board switching between pellet and wood in ESPHome would be like this
select:
- id: combi
name: Combi Management
platform: fourheat
datapoint: B20379
options:
0: "Pellet"
1: "Wood"
2: "Wood-Pellet"
3: "Combi 1"
4: "Combi 2"
There is very little chance that for you board, it could be the same so I would not get hopes too high. If not - your only remaining option is to learn communication sniffing.
wOow thx very much
Tomorrow I try it
Ho provato ma i sensori tutti non disponibili, mi puoi indicare su quale porta collegare il modulo e se hai link di tutto quello che serve per collegare la wemos? Grazie
Ho sempre una scheda ng21 e se puoi anche mandarmi la configurazione di esphome. Grazie
I tried but it doesnât work
As I suspected it was a longshot, but when you are able to find out datapoint for your board it should go similarly.
Is anyone kind enough to rewrite the procedure for wemos on NG21? Thanks.
Your contact who gave you the NG21 datapoints, could he also give us the SY250/MB250 datapoints?
no
i sent emails and called ti emme. but no answer. can anyone find the datapoints?
I noticed that sometimes I donât get any information from the logs. The log seems frozen until I restart the exp. Then I noticed some errors in the log in yellow
Good evening, I connected the module from rs232 to ttl all connected to rx and tx of a wemos d1 mini, I wrote the file in esp home it creates the sensors but they are all unknown, I canât understand why the stove doesnât communicate with me.
I have a tiemme ng21 card and I also installed the 4heat wifi module that works but even with your integration it doesnât find any entity.
I hope someone of you can help me. Thanks.
Hi everyone!
First of all, I wanted to thank all the people in this thread who have made it possible to have an Open Source alternative to the Tiemme 4Heat device, especially @leoshusar for the ESPHome component and @maxgu for all the clarifications provided.
In my case, I have a pellet stove (air type, non-ducted) from the Ferlux brand, model Flora: Modelo Flora | Ferlux
Iâm leaving here my yaml configuration for ESPHome in case it can be useful to someone with the same or similar models:
fourheat:
- id: exhaust_temperature
name: Exhaust Temperature
platform: fourheat
datapoint: J30005
device_class: temperature
unit_of_measurement: °C
- id: room_temperature
name: Room Temperature
platform: fourheat
datapoint: J30006
- id: air_flow
name: Air Flow Pressure
platform: fourheat
datapoint: J30026
device_class: pressure
unit_of_measurement: Pa
- id: combustion_fan_speed
name: Combustion Fan Speed
icon: "mdi:fan"
platform: fourheat
datapoint: J30025
unit_of_measurement: rpm
- id: auger_on
platform: fourheat
datapoint: J50010
device_class: speed
unit_of_measurement: s
- id: ambient_fan_voltage
name: Ambient Fan Voltage
platform: fourheat
datapoint: J30009
device_class: voltage
unit_of_measurement: V
- id: exhaust_depression
name: Exhaust Depression
platform: fourheat
datapoint: J30033
text_sensor:
- id: phase
icon: "mdi:chart-pie"
platform: fourheat
datapoint: J30001
options:
0: "Off"
1: "Check Up"
2: "Ignition 2"
3: "Stabilization"
4: "Ignition 4"
5: "Run"
6: "Modulation"
7: "Extinguishing"
8: "Safety"
9: "Block"
10: "Recover Ignition"
11: "Standby"
30: "Ignition 30"
31: "Ignition 31"
32: "Ignition 32"
33: "Ignition 33"
34: "Ignition 34"
- id: error
icon: "mdi:alert-circle"
platform: fourheat
datapoint: J30002
options:
0: "(None)"
1: "Safety Thermostat HV1: signalled also in case of Stove OFF"
2: "Safety PressureSwitch HV2: signalled with Combustion Fan ON"
3: "Extinguishing for Exhausting Temperature lowering"
4: "Extinguishing for water over Temperature"
5: "Extinguishing for Exhausting over Temperature"
6: "unknown"
7: "Encoder Error: No Encoder Signal (in case of P25=1 or 2)"
8: "Encoder Error: Combustion Fan regulation failed (in case of P25=1 or 2)"
9: "Low pressure in to the Boiler"
10: "High pressure in to the Boiler Error"
11: "DAY and TIME not correct due to prolonged absence of Power Supply"
12: "Failed Ignition"
13: "Ignition"
14: "Ignition"
15: "Lack of Voltage Supply"
16: "Ignition"
17: "Ignition"
18: "Lack of Voltage Supply"
- id: combustion_status
platform: fourheat
datapoint: J30011
icon: "mdi:heating-coil"
options:
1: "Power 1"
2: "Power 2"
3: "Power 3"
4: "Power 4"
5: "Power 5"
6: "Cleaning"
7: "Standby"
8: "Ignition 2"
9: "Modulation"
10: "Ignition P0"
11: "MAX P"
12: "Extinguish"
100: "Off"
110: "Off"
120: "Pmax Test"
255: "Ignition"
0: "Stabilizing"
binary_sensor:
- id: controller_status
platform: fourheat
type: module_offline
- id: room_thermostat_status
name: Room Thermostat Status
platform: fourheat
datapoint: J40007
parser: return data[data.size() - 3] == '0';
switch:
- id: status_switch
platform: fourheat
restore_mode: DISABLED
datapoint: J30001
on_datapoint: J30253
off_datapoint: J30254
on_data: '1'
off_data: '1'
parser: |-
auto size = data.size();
return
data[size - 1] != '0' ||
data[size - 2] != '0';
button:
- id: clear_error
platform: fourheat
datapoint: J30255
select:
- id: target_power
platform: fourheat
datapoint: B20816
options:
1: "P1"
2: "P2"
3: "P3"
4: "P4"
5: "P5"
6: "Auto"
number:
- id: room_target_temperature
name: Room Target Temperature
platform: fourheat
datapoint: B21700
min_value: 15
max_value: 29
climate:
- platform: fourheat
datapoint: J30001
on_data: '1'
off_data: '1'
parser: |-
return
current_temperature_datapoint: J30006
current_temperature_parser: |-
std::string int_str(data.begin(), data.end());
return stoi(int_str);
target_temperature_datapoint: B21700
target_temperature_parser: |-
visual:
min_temperature: 15
max_temperature: 29
temperature_step: 1
Additionally, Iâve taken the opportunity to add a ToF distance sensor (VL53L0X Time Of Flight Distance Sensor â ESPHome) that allows me to know the state of the pellet hopper, allowing me to program alerts in Home Assistant that notify me when I need to refill the hopper. This is the yaml configuration of that part:
globals:
# Set this to the minimun distance (in cm) from the sensor to the pellets when fully loaded
- id: capacity_distance_min
type: int
initial_value: "0"
# Set this to the maximun distance (in cm) from the sensor to the bottom of the hopper when empty
- id: capacity_distance_max
type: int
initial_value: "38"
i2c:
sda: GPIO21
scl: GPIO22
scan: True
- platform: vl53l0x
timeout: 200us
update_interval: 5s
accuracy_decimals: 2
filters:
- round: 3
- sliding_window_moving_average:
window_size: 12
send_every: 6
send_first_at: 2
- round: 2
device_class: battery
unit_of_measurement: "%"
update_interval: 30s
lambda: |-
int min = id(capacity_distance_min);
int max = id(capacity_distance_max);
if (id(vl53l0x_distance).state) {
int distance = int(id(vl53l0x_distance).state * 100);
if (distance > 1000) {
// Wrong measurement
return {};
if (distance < min) {
distance = min;
} else if (distance > max) {
distance = max;
// Calculate capcity as a percentage
return 100 - ((distance - min) * 100) / (max - min);
} else {
return {};
As a finishing touch, I designed and 3D printed a custom enclosure to house all the components. It features two RJ-11 connectors: one for the stove and the other for the pellet sensor:
And this is the ToF sensor inside the hopper:
Following up on my previous message, I wanted to see if anyone could help me with a couple of issues:
The LCD control panel on my stove isnât working properly (I think humidity has damaged the circuit during the months it hasnât been in use). The problem is that I had the stove scheduled to turn on in the morning and off at night at a certain time every weekday, and now that the panel is broken, I canât deactivate it without replacing the component (which costs âŹ80). Does anyone know if itâs possible to deactivate the scheduling using serial commands? Iâve re-read the thread several times but havenât seen anyone mention how to do it.
Another datapoint I canât figure out is the speed of the fan that expels air from the front of the stove. I usually have it at level 4 (it supports 1 to 7) and because of the same LCD problem, I canât change it either. Does anyone know what datapoint that is?
Thank you all!
Display from your link looks like a CP 115, the price is around 50 euros
From my post 211 in edit 7 where it talks about fogosur you can download the NG01 air board manual which I think your stove has, the password is 1357.
As you see depending on the setup (page 29) the fan works in a way or another.
From tpar it is very easy to do what you want but for that you must have the display although I think it could be done without the display, the important is to know what you want this fan to do, you want less noisy always, only in low powerâŚ
When you use +7 to -7 you are increasing or decreasing the speed in all powers, but if you want decrease them only in some powers I think that is not the way
I think deactivating the schedule is not possible by wifi, because it can be activated by display or by wifi, but if you activate it by display( your case) you cannot deactivate it by wifi
@maxgu yes, thatâs the display. Thanks for the link! I donât know why it was more expensive when I searched for it.
My stove has the SY100 (aka MB100), exactly the same as @jorgezazo. So I guess that manual doesnât work for me.
The user manual for my stove is this one: https://ferlux.es/wp-content/uploads/2022/03/MANUAL-GAMA-CANALIZABLE-ferlux-espanol.pdf
If you see section 6.2, what I want to configure is 6.2.1 [rAir] and 6.2.4 [Cron]. Those are user options and are outside the technical menu (6.2.8 [tPAr]).
For [rAir], I guess I can try to read different datapoints until I see one with value 4 (my current setting).
Oh, well, thatâs too bad. I guess Iâll have to end up buying a new display to deactivate it.
Thanks!
Your board is not the same that.@jorgezazo because .@jorgezazo is MB100/SYS100 Hydro board and yours is the MB100/SYS100 Air board.
They have the same hardware but different firmware.
In my post 229 edit 7 you can download Mb100 hydro Tiemme manual(.@jorgezazo)
Ferlux sometimes says it uses one board and it uses another, to know which board has, look where RJ11, RJ45 and display sockets are
About the datapoints that allow you to increase or decrease rAir, Uent and pell from +7 to -7.
I think these could be
rAir B20908
Uent B20185
Pell B20189
Positive numbers 0-7 B209080000000000x x= 0,1,2âŚ7
Negative numbers -1 to -7 B209080000000655ay a= 3 y=5 to-1, y=4 to -2âŚy=0 to -6,#### a=2 y =9 to -7
Same Uent pell
Tell me if they work on your board.Please
EDIT
The schedule that can be done with the 4Heat module and with the official Tiemme application has a particular behavior:
You can only schedule an activity if you choose weekly (every day) you cannot choose daily (only one day), on weekends here you can choose between all days except the weekend Saturday and Sunday or only Saturday and Sunday
4Heat schedule is not recorded on the board but in the cloud, so if the 4Heat module is disconnected the scheduled action does not happens, but if the 4Heat module is connected at the programmed interval time then the stove turns on
Tiemme says that you can schedule the stove with the display or with the app, but this is not true, since they work in a different way and can work at the same time.
For instance if, I schedule it with the display, on at 1 and off at 2, the schedule LED lights on the display and no widget on smartphone screen.
If I schedule it with the app, on at 3 and off at 4, on the smartphone the widget appears, but the schedule LED does not appear on the display.
What happens? the stove is put on at 1 and put off at 2, put on at 3 and put off at 4.
Are there datapoints that writes the schedule put on/off on the board? I donât know
Hi Maxgu,
Thank you for your document about Tiemme integration in Spanish! He helped us a lot. We have an old SY400 board, do you know how to receive the boiler operation status via AT commands?
Hi @maxgu
Sorry for the late answer. I have been busy with a lot of work and family visits this month.
Sorry I didnât explain well. When I said that my board was the same as the @jorgezazo one, I was referring only to the hardware. I understand that the firmware is different as mine is from a distinct Brand and Model.
This is picture of my board:
I have tried Uent (B20185) and Pell (B20189) but I get timeout when trying to read them.
For rAir (B20908) I get the value, but is always 0. This is the log from the leoshusar/4heat-esphome component:
[11:11:14][V][fourheat:215]: Sending query (index 7): 08.41.32.30.39.30.38.30.30.30.30.30.30.30.30.30.30.30.30.0D (20)
[11:11:14][V][fourheat:154]: Received data for B20908: 30.30.30.30.30.30.30.30.30.30.30.30 (12)
[11:11:14][V][fourheat.sensor:041]: 4Heat reported sensor B20908 is: 0
So I guess that is not the datapoint I was looking for.
Is there any document where I can get a list of possible datapoints form my board?
Thanks for the clarification.
I guess that my only option is to buy a new display to disable the board schedule (or trying to repair the one that I have).
After that, I will set the schedule using Home Assistant automations.
Thanks again!
