@gregoriohc
I have checked the datapoints again and they work on my stove, it seems that your datapoints are different even set temperature.
Is there any document where I can get a list of possible datapoints form my board?
I don`t know because they are specific for a board an set up, so to know the datapoints of my stove and set up, I have made an excel file, non coloured rows are my possible datapoints
https://www.solarweb.net/forosolar/attachments/usuarios-biomasa/32202d1734190836-comunicacion-rs232-modulo-wifi-4heat-tiemme-i3-i5-.xls
If that is what you want, the procedure is explained here in English/Spanish
https://www.solarweb.net/forosolar/usuarios-biomasa/58946-comunicacion-rs232-wifi-4heat-tiemme-sustitucion-esp.html
As I know little about programming and only in Arduino IDE, and I have made myself the program , the procedure is mainly based on hardware but if you know programming you can make another program or add to this one that is tested a datalog file, that records the board responds and you do not need a datalogger.
About the fan.
It works as its set up TPar Tp03 Heating Fan Menu, P06 Heating power 1= The same as combustion power 2= proportional to the exhaust temperature 3= proportional to the local room temperature.
How to change the volts?
If you know the datapoints with air or rair
If you don’t know maybe by brute force changing in TPar Tp03 Heating Fan Menu F01(0-230V) power1……F05(0-230V) power 5
That you can also change by rs232
Datapoints F01 A20579000000000000 ……, F05 A20583000000000000
Tell me what happens
EDIT
I understand that the firmware is different as mine is from a distinct Brand and Model.
The Mb100 Tiemme board has only 2 firmwares Air and hydro, and only two technical manuals Air and hydro
