Right now, the Entity Name can only be in one line.
If you are using the Tile Card in vertical Mode - with other tiles in the same row, you have limited space to display the entity name - which can be sometimes a bit longer than what can be displayed.
It would be great, if the Entity Name can be displayed over at least two lines - maybe, by using \n in between words…
here’s an older post, with the same “question” but back then, there was no tile card and the workaround was, to use other cards (custom) instead.
Unfortunately, it’s still not possible to post images to show the current behave but I think, you can imagine what I mean (and I will share a screenshot as soon as the migration is done)
