I have upgraded recently to 0.97.2 from 0.95.x . The Tile tracker tracking is now broken and supposedly it was fixed with the latest HassIO release to include the changes in the API syntax.
However for me, the log is still throwing the errors as follows
2019-08-17 13:02:29 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy
File "/usr/src/homeassistant/homeassistant/components/device_tracker/setup.py", line 69, in async_setup_legacy
hass, self.config, tracker.async_see, discovery_info
File "/usr/src/homeassistant/homeassistant/components/tile/device_tracker.py", line 74, in async_setup_scanner
return await scanner.async_init()
File "/usr/src/homeassistant/homeassistant/components/tile/device_tracker.py", line 98, in async_init
await self._async_update()
File "/usr/src/homeassistant/homeassistant/components/tile/device_tracker.py", line 129, in _async_update
gps=(tile["tileState"]["latitude"], tile["tileState"]["longitude"]),
KeyError: 'tileState'
So I am unable to decipher, what fix is needed from my side to make it work again.
The configuration file entries are left as-is , as they were working with the previous version of HassIO (0.95.x), although the breakdown I understand is not related to HassIO version change , rather being the API syntax change from Tile.
Well thanks for the reply, however I am not that technically inclined.
I am not sure and aware where to change this syntax and code, and as I understand being an end user I cannot make changes at code level myself. It has to be updated in the source and then merged with the master branch to be packaged and deployed in the production version.
So searching around I learned the HA option to override built in components by putting (updated and syntax corrected) custom components in the folder by the same name, as explained over here
Since it was mentioned here that the syntax for API has been corrected in the component file
I downloaded the updated filed from Git repository and placed them as-it-is in the custom components under a /tile folder and voila…the problem seems to be fixed.
Well another day of learning about this awesome community driven monolith.
