Tile Tracker question?
Hi there,
I have added the Tile Integration and it is showing my email address and 15 Entities of which I can see that only 4 are current (Camera, Case, Computer, Keys) the others using the same 4 names but having the suffix _replaced against them which seems self-explanatory.
I have enabled the 4 active Tile Trackers but apart from the Integration showing as mentioned above I see no reference to any of the active trackers anywhere else in HA?
There is nothing in the Log that I can see but I did see a single entry in Logbook stating Keys was detected at home which was stamped 2 hours ago so I know at least something appears to be working.
So what has happened to the other 3 Tile trackers and why do they not appear anywhere such as on the map as I have seen other screenshots showing?
Are there any other manual configurations I need to make in addition to adding the Integration or have I misunderstood how the Tile integration works within HA?
Thanks & kind regards,
-=Glyn=-
