I’m having some trouble getting customStyles to work.
I have a tile which is a script. The script toggles the shuffle mode on my sonos speaker
I’d like the background for the tile to be green if shuffle is on, no color if off. I have a sensor that monitors the shuffle status: sensor.bedroom_sonos_shuffle.
(any advice on how to have a ‘no color’ option if the arguement is false would be appreciated also)
I’ve tried simply changing the tile colour as well but nothing seems to be updating.
This, for example, doesnt change the tile background color either:
put the tileboard tree into <HA config dir>/www/tileboard/
copy ‘config.example.js’ to ‘config.js’
in web browser open http://<your HA address>:8123/local/tileboard/index.html
thx for help, but dont understand this
Copy config.example.js to config.js and edit it for your needs
config.js, where is that
sorry i am a noob for this
just if somebody runs into the same issue, meanwhile, I have found a solution - simply reboot the system. I was trying to get the blinds running through a node red automation and my node red instance runs on a linux server in a docker … and I needed to restart the node red instance in the docker for node red to recognise the new input_select entity … nothing to do with HA nor Tileboard
seeing that this is some months old I was wondering if you found a solution for the slider overlay? I have the slider available in yaml but cannot get it working in TileBoard so far. Did you make any progress with it?
I cannot believe that nobody has tried in the Climate tile to switch in the middle of the tile between the target temperature and the current temperature. I am playing around with all sorts of value definitions for the middle of the tile but it does not seem to work … I just thought I give it another try here in the group for some help on this:
I try to show the current temperature in the middle of the tile and the target temperature as a state - the state works, but the center of the tile still shows the target temperature as well, which makes no sense, imho.
Following value definition I have used (among many )
Actually, @HeyImAlex seems to have done that. At least almost by coming up with a generic popup. Maybe he’s willing to share his addition and develop it into a pull request?
Quick question: is it possible to change title and subtitle using CustomStyles depending on the state.?
I want to change color of the text depending on the value it’s state but am stuck
I am running this on a wall mounted Raspberry Pi Touch Display with a PI3 Model B and this type of screensaver is extremely slow. However, there is no problem running the same url in a popup_iframe. Not sure whats going on here. Any hint on what’s the problem or what can be done differently is much appreciated.
Thanks, i have not as I’m not sure where to start , can you push me in the right direction .?
how would a generic sample look like if for example state changes from ‘a’ to ‘b’, subtitle changes from red to green
