Ok thank you,but the popup on the tileboard that show me the camera not working,did i made any mistake?
You know, not seeing the code but knowing that it doesn’t work it is safe to assume that you have indeed made a mistake
hahahah yeah you’re right sorry here is the code that i have inserted at the TOP of the config (hope it helps):
var DOORENTRY_TILE = {
position: [4, 2],
type: TYPES.DOOR_ENTRY,
icon: 'mdi-phone',
title: 'Door entry',
state: false,
layout: {
type: TYPES.CAMERA_THUMBNAIL,
refresh: 1500,
bgSize: 'cover'
page: {},
tiles: [
// Define your tiles (door-entry buttons) here if required
this is under event:
// next fields are optional
events: [
command: 'notify',
action: function(e) {
Noty.addObject(e);
command: 'open_doorentry',
action: function(eventData) {
this.$scope.openDoorEntry(DOORENTRY_TILE, DOORENTRY_TILE.id);
then i fire up the event on HA wit tileboard command: open_doorentry
Love that.
Please show me how you are firing the event.
in hassio :
When you send notify command, does it work?
What should we use instead of CAMERA_THUMBNAIL
CAMERA or CAMERA_STREAM
Yes notify command works, after a restart from my Computer now i don’t see tileboard on the Eventlist on Hassio, but notify works well.
i think i made mistake with the variable : var DOORENTRY_TILE =
i have inserted it at the top of the config because i have received errors if i place it after, i’m not sure if the variable are now listening in this mode.
for better understanding here my config:
This is an example configuration file.
COPY OR RENAME THIS FILE TO config.js.
Make sure you use real IDs from your HA entities.
position: [4, 2],
icon: 'mdi-phone',
state: false,
layout: {
refresh: 1500,
bgSize: 'cover'
page: {},
tiles: [
var CONFIG = {
customTheme: null, // CUSTOM_THEMES.TRANSPARENT, CUSTOM_THEMES.MATERIAL, CUSTOM_THEMES.MOBILE, CUSTOM_THEMES.COMPACT, CUSTOM_THEMES.HOMEKIT, CUSTOM_THEMES.WINPHONE, CUSTOM_THEMES.WIN95
transition: TRANSITIONS.ANIMATED_GPU, //ANIMATED or SIMPLE (better perfomance)
entitySize: ENTITY_SIZES.NORMAL, //SMALL, BIG are available
tileSize: 160,
tileMargin: 6,
serverUrl: 'http://192.168.160.80:8123',
wsUrl: 'ws://192.168.160.80:8123/api/websocket',
authToken: null, // optional long-lived token (CAUTION: only if TileBoard is not exposed to the internet)
//googleApiKey: "XXXXXXXXXX", // Required if you are using Google Maps for device tracker
//mapboxToken: "XXXXXXXXXX", // Required if you are using Mapbox for device tracker
debug: false, // Prints entities and state change info to the console.
pingConnection: true, //ping connection to prevent silent disconnections
events: [
command: 'notify',
Noty.addObject(e);
timeFormat: 24,
menuPosition: MENU_POSITIONS.BOTTOM, // or BOTTOM
hideScrollbar: false, // horizontal scrollbar
groupsAlign: GROUP_ALIGNS.HORIZONTALLY, // or VERTICALLY
onReady: function () {},
header: { // https://github.com/resoai/TileBoard/wiki/Header-configuration
styles: {
padding: '20px 30px 0',
fontSize: '20px'
right: [
//type: HEADER_ITEMS.CUSTOM_HTML,
//html: '<b>LUCHOME CONTROL</b>',
//styles: {
// margin: '40px 40px 0px'
type: HEADER_ITEMS.WEATHER,
// styles: {
// margin: '0 0 0'
icon: '&sensor.dark_sky_icon.state',
icons: {
'clear-day': 'clear',
'clear-night': 'nt-clear',
'cloudy': 'cloudy',
'rain': 'rain',
'sleet': 'sleet',
'snow': 'snow',
'wind': 'hazy',
'fog': 'fog',
'partly-cloudy-day': 'partlycloudy',
'partly-cloudy-night': 'nt-partlycloudy'
fields: {
summary: '&sensor.dark_sky_summary.state',
temperature: '&sensor.dark_sky_temperature.state',
temperatureUnit: '&sensor.dark_sky_temperature.attributes.unit_of_measurement',
left: [
type: HEADER_ITEMS.DATETIME,
dateFormat: 'EEEE, LLLL dd', //https://docs.angularjs.org/api/ng/filter/date
/*screensaver: {// optional. https://github.com/resoai/TileBoard/wiki/Screensaver-configuration
timeout: 300, // after 5 mins of inactive
slidesTimeout: 10, // 10s for one slide
styles: { fontSize: '40px' },
leftBottom: [{ type: SCREENSAVER_ITEMS.DATETIME }], // put datetime to the left-bottom of screensaver
slides: [
{ bg: 'images/bg1.jpeg' },
bg: 'images/bg2.png',
rightTop: [ // put text to the 2nd slide
type: SCREENSAVER_ITEMS.CUSTOM_HTML,
html: 'Welcome to the <b>TileBoard</b>',
{ bg: 'images/bg3.jpg' }
pages: [
title: 'HOME CONTROL',
bg: 'images/bg6.jpg',
icon: 'mdi-home-outline', // home icon
groups: [
title: 'Aktuelles Wetter',
width: 3,
height: 2,
items: [
position: [0, 0],
height: 2,
type: TYPES.WEATHER,
id: {}, // using empty object for an unknown id
icons: {
'cloudy': 'cloudy',
'rain': 'rain',
'sleet': 'sleet',
'snow': 'snow',
'wind': 'hazy',
'fog': 'fog',
fields: {
windSpeed: '&sensor.dark_sky_wind_speed.state',
windSpeedUnit: '&sensor.dark_sky_wind_speed.attributes.unit_of_measurement',
humidity: '&sensor.dark_sky_humidity.state',
humidityUnit: '&sensor.dark_sky_humidity.attributes.unit_of_measurement',
//state: false, // disable state element
list: [
// custom line
'Gefühlt wie '
+ '&sensor.dark_sky_apparent_temperature.state'
+ '&sensor.dark_sky_apparent_temperature.attributes.unit_of_measurement',
// another custom line
'Luftdruck '
+ '&sensor.dark_sky_pressure.state'
+ '&sensor.dark_sky_pressure.attributes.unit_of_measurement',
// yet another custom line
'&sensor.dark_sky_precip_probability.state'
+ '&sensor.dark_sky_precip_probability.attributes.unit_of_measurement'
+ ' Regen'
position: [0, 2],
theme: ITEM_TRANSPARENT,
type: TYPES.SENSOR_ICON,
title: 'Eingangstüre',
states:
Offen: "Offen",
Geschlossen: "Geschlossen"
customStyles:
function(item, entity) {
if (entity.state === 'Offen') {
return { 'background-image': 'url("images/icon/door-open-modify.png")'
}else if (entity.state === 'Geschlossen') {
return { 'background-image': 'url("images/icon/door-closed-modify.png")'
position: [1, 2],
title: 'Wohnzimmertüre',
states: {
Offen: "Offen",
Geschlossen: "Geschlossen",
customStyles:
return { 'background-image': 'url("images/icon/door-open-modify.png")',
position: [2, 2],
width: 1,
type: TYPES.SWITCH,
title: 'AUS / EIN',
subtitle: 'ALLE LICHTER',
states: {
on: "AN",
off: "AUS"
icons: {
on: "mdi-lightbulb-on",
off: "mdi-lightbulb",
position: [1, 0],
type: TYPES.WEATHER_LIST,
width: 2,
height: 2,
title: '',
icons: {
'cloudy': 'cloudy',
'rain': 'rain',
'sleet': 'sleet',
'snow': 'snow',
'wind': 'hazy',
'fog': 'fog',
customStyles: {'fontSize': '16px'},
hideHeader: false,
primaryTitle: 'Vorhersage',
secondaryTitle: 'Regen',
list: [0,1,2,3,4,5,6,7].map(function (id) {
var weekday = [ "Sonntag", "Montag", "Dienstag", "Mittwoch", "Donnerstag", "Freitag", "Samstag" ];
var forecast = "&sensor.dark_sky_overnight_low_temperature_" + id + "d" + ".state - ";
forecast += "&sensor.dark_sky_daytime_high_temperature_" + id + "d" + ".state";
forecast += "&sensor.dark_sky_daytime_high_temperature_" + id + "d" + ".attributes.unit_of_measurement";
var precip_probability = "&sensor.dark_sky_precip_probability_" + id + "d" + ".state" + ' %' ;
return {
date: function () {
if ( id === 0 ) {
return "Heute";
else if ( id === 1 ) {
return "Morgen";
var d = new Date(Date.now() + id * 24 * 60 * 60 * 1000);
return weekday[d.getDay()];
icon: "&sensor.dark_sky_icon_" + id + "d" + ".state",
//iconImage: null, replace icon with image
primary: forecast,
secondary: precip_probability
title: 'Fensterstatus',
width: 3,
height: 2,
items: [
position: [0, 1],
width: 0.5,
height: 0.5,
title: 'Küche',
state: false,
customStyles:
if (entity.state === 'off') {
return { 'background-image': 'url("images/icon/window-closed-modify.png")', 'fontSize': '12px',
}else if (entity.state === 'on') {
return { 'background-image': 'url("images/icon/window-open-modify.png")'
position: [0.5, 1],
width: 0.5,
height: 0.5,
title: 'Küche',
state: false,
customStyles:
return { 'background-image': 'url("images/icon/window-open-modify.png")', 'fontSize': '12px'
position: [1, 1],
width: 0.5,
height: 0.5,
title: 'WC',
state: false,
customStyles:
position: [1.5, 1],
width: 0.5,
height: 0.5,
title: 'WC',
state: false,
customStyles:
position: [0, 1.5],
width: 0.5,
height: 0.5,
title: 'Eltern',
state: false,
customStyles:
position: [0.5, 1.5],
width: 0.5,
height: 0.5,
title: 'Elia',
state: false,
customStyles:
position: [1, 1.5],
width: 0.5,
height: 0.5,
title: 'Ariana',
state: false,
customStyles:
position: [0, 2.5],
width: 0.5,
height: 0.5,
title: 'Wohnen',
state: false,
customStyles:
position: [0.5, 2.5],
width: 0.5,
height: 0.5,
title: 'Wohnen',
state: false,
customStyles:
position: [1, 2.5],
width: 0.5,
height: 0.5,
title: 'Wohnen',
state: false,
customStyles:
position: [1.5, 2.5],
width: 0.5,
height: 0.5,
title: 'Wohnen',
state: false,
customStyles:
position: [0, 2],
width: 0.5,
height: 0.5,
title: 'Treppe',
state: false,
customStyles:
position: [0.5, 2],
width: 0.5,
height: 0.5,
title: 'Waschen',
state: false,
customStyles:
position: [1, 2],
width: 0.5,
height: 0.5,
title: 'Büro',
classes: ['-customcenter'],
state: false,
customStyles:
return { 'background-image': 'url("images/icon/window-closed-modify.png")', 'fontSize': '11px',
position: [2.2, 0],
width: 2,
height: 2,
type: TYPES.IMAGE,
state: false,
title: false,
bgSuffix: '@attributes.entity_picture'
position: [2.2, 1],
width: 2,
height: 1,
bgOpacity: 2,
type: TYPES.MEDIA_PLAYER,
hideSource: false,
hideMuteButton: false,
state: false,
source_list: true,
//state: '@attributes.media_title',
subtitle: '@attributes.media_title',
//bgSuffix: '@attributes.entity_picture',
title: 'Second page',
icon: 'mdi-numeric-2-box-outline',
groups: [
title: '',
width: 2,
height: 3,
items: [
position: [3, 0],
bgSize: 'cover',
width: 2,
state: false,
fullscreen: {
type: TYPES.CAMERA_STREAM,
objFit: 'contain',
id: 'camera.camera_name', // Optional: camera entity to use on fullscreen, defaults to the tile camera entity if omitted
bufferLength: 5 // Optional: buffer length in seconds for the HLS buffer, default is 5 seconds
position: [0, 0],
width: 2,
title: 'Short instruction',
type: TYPES.TEXT_LIST,
list: [
title: 'Read',
icon: 'mdi-numeric-1-box-outline',
value: 'README.md'
title: 'Ask on forum',
value: 'home-assistant.io'
title: 'Open an issue',
icon: 'mdi-numeric-3-box-outline',
value: 'github.com'
position: [0, 1.5],
width: 1.5,
height: 1,
title: 'My Gauge Title',
subtitle: '',
type: TYPES.GAUGE,
id: 'sensor.my_sample_sensor', // Assign the sensor you want to display on the gauge
value: function(item, entity) {
return entity.state;
settings: {
size: 200, // Defaults to 50% of either height or width, whichever is smaller
type: 'full', // Options are: 'full', 'semi', and 'arch'. Defaults to 'full'
min: 0, // Defaults to 0
max: 25000, // Defaults to 100
cap: 'round', // Options are: 'round', 'butt'. Defaults to 'butt'
thick: 8, // Defaults to 6
label: 'My Gauge', // Defaults to undefined
append: '@attributes.unit_of_measurement', // Defaults to undefined
prepend: '$', // Defaults to undefined
duration: 1500, // Defaults to 1500ms
thresholds: { 0: { color: 'green'}, 80: { color: 'red' } }, // Defaults to undefined
labelOnly: false, // Defaults to false
foregroundColor: 'rgba(0, 150, 136, 1)', // Defaults to rgba(0, 150, 136, 1)
backgroundColor: 'rgba(0, 0, 0, 0.1)', // Defaults to rgba(0, 0, 0, 0.1)
fractionSize: 0, // Number of decimal places to round the number to. Defaults to current locale formatting
id: ‘camera.camera_name’, ? Supposed this is not the actual id of your camera? Try including the tile on one of the pages:
items: [
DOORENTRY_TILE,
position: [0, 0],
height: 2,
See if you are able to click it and in opens fine.
hi.
Yes id camera.camera_name is correct because it’s only test at the moment, i don’t have received my cameras yet. i have inserted the tile on one of the page and i see now the tile with the Phone icon, on click it make nothing?? did i can see a log what it’s try and dosen’t work?
So TYPE.CAMERA worked, but TYPE.CAMERA_STREAM did not. And now I might as well fix my click on the camera, which calls TYPE.CAMERA_STREAM and indeed does not work. Any ideas? It is an LTS (hikvision) camera.
// GARAGE CAM \\
position: [2, 2],
title: '',
type: TYPES.CAMERA,
bgSize: 'cover',
width: 4,
height: 2,
state: false,
filter: function(url) {return "https://10.191.30.52:8765/picture/1/current/"},
fullscreen: {
// bgSize: 'contain',
// refresh: 1500,
// filter: function(url) {return "http://10.191.30.52:8081"},
refresh: function () { // can also be a function
return 3000 + Math.random() * 1000;
Hi All,
does anyone know of a tile that can loop through an array on a timer?
Or how easy it is to create one?
The reason i ask is that i am using a feed parser that gives me the following:
Entity:
sensor.bbc_news
State:
72 (but changes on qty of news items)
attributes:
entries:
- title: ‘Coronavirus: Five and overs in UK now eligible for test’
link: ‘https://www.bbc.co.uk/news/uk-52713127’
image: ‘https://www.home-assistant.io/images/favicon-192x192-full.png’ - title: ‘Coronavirus symptoms: UK adds loss of smell and taste to list’
link: ‘https://www.bbc.co.uk/news/health-52704417’
image: ‘https://www.home-assistant.io/images/favicon-192x192-full.png’ - title: ‘Coronavirus: NI Executive agrees to lift more lockdown measures’
link: ‘https://www.bbc.co.uk/news/uk-northern-ireland-52711301’
that’s the top three.
i was just interested to see if anyone had down this - i thought of a ticker style scroller or marques tile - or a tile that changes at a set interval…
Thanks for any pointers.
Jason
The CAMERA_STREAM works with Real Time Streaming Protocol (rtsp). I had to change my Wyze cam to a rstp firmware in order to get it working. I saw somewhere, someone is using VLC to create an rstp stream with a local file. ffmpeg may also be an option.
My HA for rstp stream:
- platform: ffmpeg
input: -rtsp_transport tcp -i rtsp://IP_ADDRESS/live
Create a input_number in HA and a automation to increase the number on delay triggered based on time.
Using input_number entity in TB as an index to get the element in your array/object.
I have similar automation for my sprinkler system except each of my delays are using input_number.
Hi all - first awesome project, and i completely get why people are so active on this.
Been going through setup for this last couple of days, and thought i was starting to get to grips with it all - but spent the last few hours bashing my head against the wall trying to get the header_items.weather object to appear on the right hand side of the header . . . but nothing.
Turns out, DarkSky was purchased by Apple, and no new public api access - is there a new method for this, apologies if this has been covered previously, i did search and didnt find anything ?
Hello
I’m accessing my HA via duckdns, but tested it having problems accessing Tilebord, what appears to me is only the background screen and the screensaver also appears. I can access the files from the tileboard directories as well. But I don’t know what the screens are not showing. Can someone help me with this please?
