I have some electric blinds, but they do not report the state. I have them setup with RFXCOM RFXtrx and they are working fine. The issue I have is that when the blinds are down, and someone uses the remote to put them up, I cannot then use my TileBoard setup to lower them, as the state in Home Assistant is closed. Is there a way to setup the cover so that the state is ignored?
Ideally I’d like to be able to click the Up arrow and it calls the cover.open service and clicking down calls the cover.close service
I installed Tileboard, as a separate docker container, and configured a few things. All is well, except for adding custom CSS. There is no mention of how to add custom.css file using docker installation. Can someone please help with this?
I have the same ERR with LordHayne,you said whit add-on tileboard directory just only contain config.js and custom.css. which way can I get the custom.css?And delate the other folder in tileboard ?
Hey, I am having some problems with the Add-on. After I installed it, I created a folder called tileboard in my config folder. Inside the tileboard folder, I created a file called config.js, where I pasted the example configurartion.
When opening the webUI, I get: "please make sure that you have “config.js” file and it is a valid javascript! if you are running tileboard for the first time, please rename “config.example.js” to “config.js” as a pop-up
I really want this to work! I have installed as addon on Homeasssistant, I have duckdns ssl running and would like to access the tileboard at a different port than my HA instance, when I specify another port, I get the cipher error. and find no way to change that
Hi @Emilic did u succseed? I’ve managed to open the tile board, but no tiles is working, i can only left in config the header part, otherwise i got black screen ;(
Dear TileBoard users,
i know the topic been discussed several times but I still struggling with simple step… accessing to the add-on configuration via external secured link (over https://)
How can I do it? I’m getting “ERR_SSL_VERSION_OR_CIPHER_MISMATCH” message instead of my beautiful dashboard
Any help?
I have the TileBoard Addon installed on a RaspBerry Pi4, and I want to know how to access only the content of the addon, without the Home Assistant UI menu.
Maybe through a link or something since I want to put TileBoard on a tablet with a kiosk application so that it opens the link directly.
If not, what alternatives do I have?
SOLUTION:
I have found the link, in the logs of the addon, I saw the link.
In the logs, go to client; xxxxx, server: xxxxx, request: xxxxx, host: xxxxx, referrer: (the link) “https://your_host:8123/api/hassio_ingress/xxxxx”
