Now everything displays fine, and I can see the title state change when a face is detected BUT I see no icon intitially or any icon change. I assumed I could used a simple sensor icon type as these work perfectly for my other motions detection sensors.
Do you think a new type would be needed to display the WallPanel face detection?
Yeah as soon as I posted I worked it out… I could see the example on GitHub but couldn’t see the explanation as to why you have to add .state and .attributes. I assumed wrongly it would just add the state as default when adding the sensor.
Is it possible to change the colour of the icon for a sensor tile based on state.
e.g.
open/on =red
closed/off = yellow
For my alarm panel i have all my doors /windows showing and at the moment it hard at a glance to see what is open or closed.
If its possible, could you direct me what i need to change
Hi all,
I’ve been trying to figure out how to get the time and date to be side by side rather than time above date in HEADER_ITEMS.DATETIME. Has anyone been able to do this, it’s still a step beyond me…
I don’t think I’m proficient enough in CSS to add it for just that sensor. Also after playing in chrome dev console I think if I do manage to do it the text will not be wrapped to form a block and will still disappear out of view.
@apt I just came to start adding my plants I like your solution.
Yes using MiFlora, I’m using a bluetooth USB into my server which has been bulletproof for a long time. I recently put a couple outside to see if they withstand the British elements. These were sending intermittently so I made a plant gateway with a pi-zero and put it closer. So far so good. What solution do you use?
