TileBoard - New dashboard for Homeassistant
Why not create a tile with date if you need one? You can (probably) add z-index rule to custom.css to work around it but the whole idea of placing header into the footer is not ok.
Can you share a picture of what your layout looks like on the Fire 7 with those settings?
I have created a tile with the time and date but i like the way it appears as the header, just in the footer. I’m using a small screen so need to keep it compact.
I am really digging this frontend. however when Itry to get sensor data in a type: text_list the value is outputting a string
    title: "Download",
    icon: "mdi-download",
    value: "sensor.speedtest_download"
where value should be 0.67 I am getting “sensor.speedtest_download”
I’ve tried with “&sensor.speedtest_download” as well. I don’t understand what is afoot here.
Give this a try:
  title: 'Download',
  icon: 'mdi-download',
  value: '&sensor.speedtest_download.state' + '&sensor.speedtest_download.attributes.unit_of_measurement'
you forgot .state
.state shouldn’t be needed for the attributes and it’s there for the actual state. I did do a terrible job of pasting in in though. This is better:
          title: 'Download', icon: 'mdi-download',
I was replying via my phone, I was meant to reply to a different message :slight_smile:
Couple of images below lifted from FullyKiosk on the Fire7 looks identical just bigger on the bigger fires. Ignore the list sensor on main page its WIP.
Hope this helps.
that was it, thanks!
the only thing I would change is weather forecast. I would get rid of the header:
hideHeader: true
And display dates as Weekdays:
var d = new Date(Date.now() + id * 24 * 60 * 60 * 1000);
var date = d.toString().split(' ')[0];
Other than that this is perfect example of a dashboard that has some style :slight_smile:
Thanks for the tip on weekdays the date format had been bugging me! :+1::grinning:
now to get a weather block looking more like this Capture
icon, data summary then maybe 5-day forecast or hourly.
Having a little trouble with the slider tile.
It seems to be addressing the state rather than the brightness.
TB%20slider
My confiig for this slider:
           width: 3,
           type: TYPES.SLIDER,
					   theme: ITEM_TRANSPARENT,
					   unit: '%',
					   title: 'Kitchen',
					   subtitle: 'Volume',
					   state: false,
					   slider: {
					     // max:100,
						 // min: 0,
						 // step: 2,
						  request: {
						     type: "call_service",
							 domain: "input_number",
							 service: "set_value",
							 field: "value"
My config for volume control in HA:
   - platform: mqtt
    state_topic: "cbus/read/254/56/130/state"
    command_topic: "cbus/write/254/56/130/switch"
    brightness_state_topic: "cbus/read/254/56/130/level"
    brightness_command_topic: "cbus/write/254/56/130/ramp"
    qos: 0
	payload_off: "OFF"
    optimistic: false`
Any suggestions?
Please format your code properly as it is impossible to read. You mention brightness, control says volume…?
Slider can only control input_number components.
You can’t. We have two different tiles, one for current weather and one for forecast.
No doubt that will be the issue. My home automation is C-Bus so volume controls are on the same system as the lighting - brightness = volume.
I’d love to see the ability to override icons with something like font awesome or the link.
currently if you include font awesome you have t remove mdi or the mdi class clashes. This is awesome stuff though
You can create a separate input_number in HA to actually control the volume.
mdi-xxx is simply CSS class, so if you create your own classes for font awesome or any other third-party font icons, it should work just fine.
