TileBoard - New dashboard for Homeassistant
I don’t think there is an elegant way of doing it at the moment and TEXT_LIST was never intended to do this.
Amazing! You are the best and thank you again for this fantastic project
@resoai - Thanks for creating and sharing such a wonderful dashboard.
so far managed to customize to fit my needs to show dashboard on 8" display.
Hey guys,
Any suggestions how i can add a slider for the colourr?
I’ve changed “Brightness” with “rgb_color” but no luck
position: [4.07, 1.05],
width: 0.9,
height: 1.12,
title: ‘LIFX2’,
type: TYPES.LIGHT,
states: {
on: “On”,
off: “Off”
icons: {
on: “mdi-lightbulb-on”,
off: “mdi-lightbulb”,
sliders: [
title: ‘Brightness’,
field: ‘brightness’,
max: 255,
min: 0,
step: 5,
request: {
type: “call_service”,
domain: “light”,
service: “turn_on”,
field: “brightness”
Thanks Alexey. I appreciate the response. :+1:
Can you tell how I can make the slide (the square) a bit bigger?
Want to make it more comfortable to use on ipad…
Thanks!
I’m stuck, help please.
I have Broadlink Rm Pro and an IR light with on/off and day/night switch.
How can I use this light in one tile to toggle the on/off and the day/light switch?
You need to make those bigger:
  input[type=range]::-webkit-slider-thumb {
  input[type=range]::-moz-range-thumb {
  input[type=range]::-ms-thumb {
Thanks!
this solved it (to custom.css):
  height: 30px !IMPORTANT;
  width: 30px !IMPORTANT;
  margin-top: -14px !IMPORTANT;
  border-radius: 7px !IMPORTANT; /*only if you like..*/
@resoai can you tell if it’s possible to handle click on sensor to fire an action?
For example if I click on some temperature sensor it will toggle some other switch?
No, a sensor by definition is something which displays the information and doers not perform any action.
Understood, thanks!
If you still want to get your hands dirty, you could edit controllers/main.js to handle the click.
yes, i saw the $scope.entityClick = function and it can be implemented easily…
But I just need to think first if I want to maintain my side branch or to be aligned to yours…
Just found this and would love to use it but I’m struggling a bit as I don’t know where to put the files.
I changed the page title in /home/pi/homeassistant/lib/python3.5/site-packages/hass_frontend/index.html and that showed up on my normal dashboard to I assumed that I should put the TileBoard directory in here to get:
/home/pi/homeassistant/lib/python3.5/site-packages/hass_frontend/TileBoard
And that I would access this via mi.ip.add.ress:8123:TileBoard
However, I just get a 404 error.
Any pointers would be gratefully received
Ignore this. It was me being dumb!
I’ve just enabled presence detection through my Netgear Router. Is there a tile I could use to show whether people are in or out?
That’s not only great, but close to what I’m trying to build.
Quick question. How do you get the recycling info?
I made changes to tileboard/config.js but when I restart my hassio nothing changed…do I need to do something else? I can’t get the index.html to show my changes, very strange…
This looks far better for tablet devices, but doesn’t seem to be working for me, however I’m using the compact theme, what theme are you using? Thanks
EDIT: After adding in the input[type=range]::-moz-range-thumb part to my .css it now works for me :slight_smile: I should have read the whole thread.
EDIT 2: Is it possible to change the slider position on the Light tiles?
My bulbs only have brightness control and I’d like to move the slider to the centre of the tile, not the top.
