Tilt Functionality not Working with Aeotec Multi Sensor and Door/Window Sensor
I am migrating from SmartThings over to HA and have quite a few Aeotec Multipurpose Senors and Aeotec Door/Window Sensor 7 Pro left over I’d like to use with HA.
I was able to add both easily via ZHA and ZwaveJS. Both report accurately for open and close status, however, neither report tilt. The Multi sensor doesn’t even show the option while the Door/Window 7 sensor shows tilt but it’s greyed out (see photos). I’ve done my Googling and haven’t rely come across much on the tilt function not working for people.
Does anyone have any ideas? I have a lot of automations that rely on tilt and have worked wonderfully in ST. Thank your for reading this!
I have the same problem, is there any solution for this issue?
Solution is as follow:
You can click into the entity “Sensor state (Tilt)” and activate it.
After 30 seconds and when your device will be triggered again, it will appear as active entity and will show you the state.
I’m using the aoetec gen7 z-wave stick.
