Time and sunset automation
Hi. I’m looking for a bit of help on an automation I’d like to create. It seems simple but I just cannot figure it out!
I’ve got a light that I’d like to switch on at 5.30 if the sun has set. If the sun has not set at this time the light should switch on when it does.
This is my (not working) code so far:
- alias: Lamp - on in the evening
  - platform: time
    after: '17:30'
  condition:
    condition: and
    conditions:
    - condition: time
      before: '23:59'
    - condition: sun
      after: sunset
  - service: light.turn_on
      entity_id: light.lamp
This will turn the light on at 5.30 if the sun has set but it never turns on if the sun sets after 5.30.
Thanks for any help :slight_smile:
Put a trigger for sunset in also. That way it will trigger at 5:30 and sunset. If the sun has not set at 5:30 the condition you already have will prevent the light from turning on, however, once the sun sets it will turn on.
Alternatively, switch the logic so that the trigger is sunset, and the condition is after 17:30. You don’t need to check that it’s before midnight, since after sunset infers that (after sunset covers until midnight, before sunrise after midnight).
  - platform: sun
    event: sunset
  condition:
    condition: time
    after: '17:30:00'
I read his request as on at 5:30 if the sun is already down, if the sun is not down wait until it sets and then turn on the light.
With only the sunset trigger it will only trigger at sunset. Not at 5:30, sunset can be after 9:00 in the summer.
So, light should go on at sunset but not before 5:30?
Thanks for the replies! I just couldn’t get my head around this one but I’m pretty sure having the time and sunset as triggers with a condition to check if the sun has set will work.
Here’s what I have:
  - platform: time
    after: '17:30'
  - platform: sun
    event: sunset
  condition:
  - condition: sun
    after: sunset
I’ll let you know how it goes.
Thanks again.
I’m having a simular situation with the following automation:
- alias: 'Lights on when home after sunset'
    platform: state
    entity_id: device_tracker.xxxxx
    state: 'home'
  condition:
    condition: sun
    after: sunset
    after_offset: "-0:20:00"
        entity_id: light.hall_way
        brightness: 125
        entity_id: light.diner_table
        brightness: 125
        entity_id: light.living_room
        brightness: 140
        entity_id: light.PC
        brightness: 240
    - service: switch.turn_on
      entity_id: switch.wake_on_lan
    - service: tts.google_say
      data_template:
        entity_id: media_player.home_group
        message: 'Welcome Home!'
        cache: false
The automation triggers fine if I arrive home after sunset. What I want is that the automation also triggers when the sun sets if I’m allready home before that time (which it doesn’t at the moment).
Do I have to setup a second automation for this with a sun trigger?
I don’t think that will work. Logically read it says
if (17:30 OR sunset) AND (after sunset) then
So, it will work on sunset (event if it is before 17:30), but not if 17:30h is before sunset. Again, please specifiy what you want to achive.
  1. lights on at sunset, but not before 17:30 OR
  2. lights on at sunset, but latest at 17:30
Regards
Will this work?
    - platform: state
      entity_id: device_tracker.xxxxxx
      state: 'home'
    - platform: sun
      event: sunset
  condition:
    condition: and
    conditions:
      - condition: sun
        after: sunset
      - condition: state
        state: 'home'
        brightness: 125
        brightness: 125
        brightness: 140
        entity_id: light.PC
        brightness: 240
What I’m trying to achieve is;
  • When entering home after sunset, run automation.
  • When sun sets if I’m allready home, run automation.
Can’t get the “after_offset” to work so ignore that line (it will never be triggered).I will also not block my automation because 20 min’s before sunset the condition will turn to “true” (right?)
I think that sunset condition won’t work. It won’t be 20 min before sunset when the sun sets and that’s a very specific time to meet when you come home. Otherwise looks good.
@silvrr Thanks, I’ll delete that line and wait at home untill the sun sets to see if it works :wink:
Update:
This should work according to the docs:
    - platform: state
      state: 'home'
    - platform: sun
      event: sunset
      offset: "-0:20:00"
  condition:
    condition: and
    conditions:
      - condition: sun
        after: sunset
      - condition: state
        state: 'home'
https://home-assistant.io/cookbook/automation_sun/
Allright. What am I doing wrong (and what can be more efficient). Since I’ve changed some of the lines (brightness and combining switches and ligts) my HA won’t start anymore
## Ben ik thuis zet dan de lampen op 150% 1,5 uur voor zonsondergang
- action:
      brightness: 150
      rgb_color: [255,205,115]
      entity_id: light.tradfri_group_4
    service: homeassistant.turn_on
  alias: Thuis na zonsondergang (fase 1)
  condition:
  - condition: state
    entity_id: device_tracker.xxxxxxxxxx
    state: home
  - event: sunset
    offset: -01:30:00
    platform: sun
## Ben ik thuis zet dan de lampen op 200% 45 min voor zonsondergang
- action:
      brightness: 200
  alias: Thuis na zonsondergang (fase 2)
  condition:
  - condition: state
    state: home
  - event: sunset
    offset: -00:45:00
    platform: sun
## Ben ik thuis zet dan de lampen op 250%  tijdens voor zonsondergang en zet de ikea lampen aan
- action:
      brightness: 250
      entity_id:
        - light.tradfri_group_4
        - switch.ikea_lamp_woonkamer
        - switch.ikea_lamp_keuken
  alias: Thuis na zonsondergang (fase 3)
  condition:
  - condition: state
    state: home
  - event: sunset
    platform: sun
## schakel alle lapen uit als ik weg ben
- action:
  - data:
      entity_id:
        - group.all_lights
    service: homeassistant.turn_off
  alias: Lampen uit als ik weg ben
  condition: []
  - entity_id: device_tracker.xxxxxxxxxx
    platform: state
    to: not_home
## zet ik de TV aan, zet dan de sonos1 speakers uit
- action:
  - data:
      entity_id: media_player.huiskamer
  alias: TV aan = Sonos uit
  condition: []
  - entity_id: media_player.tv_woonkamer
    platform: state
    to: playing
## Kom ik thuis 1,5uur voor of na zonsondergang, doe dan de lampen op 150%
- action:
  - data:
      brightness: 150
  alias: Thuiskomen na zonsondergang
  condition:
  - after: sunset
    after_offset: -01:30:00
    before_offset: -00:45:00
    condition: sun
    platform: state
    to: home
## Kom ik thuis tijdens of na zonsondergang, doe dan de lampen meteen op 250% en de ikea lampen aan
- action:
      brightness: 250
      entity_id:
  alias: Ikea lamp na 18:00 als ik thuis kom
  condition:
    condition: and
    conditions:
      - condition: sun
        after: sunset
      - condition: time
        before: '23:59'
    platform: state
    to: home
At first glance your indentation doesn’t look right. Yaml is VERY strict on indentation. You may want to review this first. You’ll need trigger, condition and action on the same level to start with…
The indentation is based on the automation that Hass.io made in the first place. I’ve just added some lines to create a flow in brightness based on the sunset.
The problem was - afterwards - the ID’s. They weren’t unique and that caused some problems. It’s fixed now =) Thanks though
Thanks. When I replied I was checking your code on my phone
Guess I won’t do that anymore :wink:
