Time based automation to also start acting on devices set to On before?
I’ve been running an automation that turns off my lights after 15 mins between 00:00 and 07:00.
But obviously if a light is already On when it gets to 00:00 it doesn’t start tracking/running on this light.
Is there some way to make an automation run even on devices/entities that are already in the state the automation expects them to switch to?
Or maybe there’s a blueprint around for it, but I haven’t found it. Not sure what to search for tbh.
Current automation:
alias: Woonkamer Achter - Light Off after Midnight
description: Turn off lights after 15 mins between 00:00 and 07:00
  - platform: device
    type: turned_on
    device_id: c68db30a55480377421bbfcace12bfa4
    entity_id: light.hue_white_filament_bulb_g93_e27_woonkamer_achter
    domain: light
    for:
      hours: 0
      minutes: 15
      seconds: 0
condition:
  - condition: time
    after: '00:00'
    before: '07:00'
  - service: light.turn_off
      transition: 2
mode: restart
That’s not true.
e.g. If the light gets turned on at 23:50, then at 00:05 the automation triggers and then the time condition is checked and it passes.
Ah, but then what if the light has been on since 23:00?
Currently it doesn’t turn off with the above automation.
But I do want it to be affected by the 15 min rule from the midnight point.
  - platform: state
    to: 'on'
    for:
      minutes: 15
  - platform: time
    at: '00:00'
condition:
  - condition: time
    after: '00:00'
    before: '07:00'
  - condition: template
    value_template: >
      {{ trigger.platform == 'state' or
        (is_state('light.hue_white_filament_bulb_g93_e27_woonkamer_achter', 'on') and
            (now() - states.light.hue_white_filament_bulb_g93_e27_woonkamer_achter.last_changed).total_seconds() > 900) }}
      transition: 2
mode: restart
It triggers at 00:00 and the Template Condition checks if the light has already been on for at least 15 minutes (900 seconds). If it is then it’s turned off immediately.
Just add a time trigger at 00:00, then
Couldn’t you make this simpler by making the trigger do most of the work?
    value_template: >-
      {{ is_state('light.hue_white_filament_bulb_g93_e27_woonkamer_achter', 'on') and
        ( utcnow()| as_timestamp -
        states.light.hue_white_filament_bulb_g93_e27_woonkamer_achter.last_changed | as_timestamp > 900 ) }}
condition:
  - condition: time
    after: '00:00'
    before: '07:00'
  - service: switch.turn_off
mode: single
I’d say it’s a matter of preference regarding how the automation’s triggers are handled.
In the example I posted, the triggers are evaluated when one of two discrete events occurs:
  • At a specific time.
  • When the light is on for 15 minutes.
The condition is evaluated only when either of those two events occurs.
In your example, the inclusion of utcnow() mandates an evaluation of the Template Trigger every minute.
FWIW, wherever possible, I prefer to have the efficient, backend python code handle timed events.
Good to know.
FWIW, if the goal is to make the Template Trigger do all of the work, you can make it check the time-range, thereby eliminating the Time Condition.
    value_template: >-
      {% set light = 'light.hue_white_filament_bulb_g93_e27_woonkamer_achter' %}
      {{ is_state(light, 'on') and 0 <= now().hour < 7 and
        (now() - states[light].last_changed).total_seconds() > 900 }}
condition: []
mode: single
EDIT
This might works as well but I haven’t had the time to test it (I rarely use trigger_variables).
trigger_variables:
  light: 'light.hue_white_filament_bulb_g93_e27_woonkamer_achter'
    value_template: >-
condition: []
      entity_id: '{{ light }}'
mode: single
Thanks. I’ll be using a slightly altered version of the first post from Taras.
But this way it works just fine for my purpose.
I tried both ways, but I prefer it not running every minute.
And since either work I’ll take the Condition template way.
Here’s my resulting automation. It has some obsolete values, but that’s just because I prefer to edit via the GUI.
  - platform: state
    to: 'on'
    for:
      hours: 0
      minutes: 15
      seconds: 0
  - platform: time
    at: '00:00:00'
condition:
  - condition: time
    after: '00:00'
    before: '07:00'
    value_template: |-
      transition: 2
mode: single
