HI all - first post - I have just started using HA - Old Mac mini is the hardware platform running on a Virtual Box VM - also running Mosquito Broker on same VM. I am getting no timing consistency on my very basic automations. CPU utilisation around 15%. All interactions through the front end are quick - devices are Sonoff/Shelley/Phillips Hue/Ring/Ecobee/Flume/Airthings and a few others.
I used the Sun integration for Sunset/Sunrise to trigger a few devices and some Fixed time Automations to switch some devices on/off. The issue is there is no consistency - when I look at the automation traces they trigger all over the place but always late. Any ideas as to what could be causing this? My initial thought was Hardware constraints but I am not seeing anything obvious. Is there a scan time that can be set for automation triggers to evaluate conditions.
