I have an automation that can fire between 9 am and 1 hour prior to sunset. That’s the easy part. But I do not want it to between 2:15 pm - 2:45 pm. I added a NOT condition, but I’m pretty sure it will not work correctly. Thoughts?
condition:
condition: and
conditions:
- condition: time
after: '09:00:00' # Starts at 9:00 am
- condition: sun
before: sunset
before_offset: '-01:00:00' # Stops firing 1 hour prior to sunset
- condition: not
conditions:
- condition: time # Should not fire between 2:15 pm - 2:45 pm
after: '14:15:00'
before: '14:45:00'
I can’t say if your idea will work, but I’d do it a little simpler. Set the time in an or condition and make one from 09:00 (after) to 14:15 (before) and the other one from 14:45 (after). The sunset can stay in place.
It is actually a little more complicated because there are a couple of different windows when I do not want the automation to fire. I came up with a way to handle it, but maybe you’ll have a cleaner/better way. Below is the full automation:
# Turn On Jumping Spider
- id: jumping_spider_on
alias: 'Jumping Spider On'
initial_state: true
mode: single
- platform: state
entity_id: binary_sensor.front_door_motion
- platform: state
entity_id: binary_sensor.front_porch_motion_sensor_motion
condition:
condition: and
conditions:
- condition: time
- condition: sun
before: sunset
- choose:
- conditions:
# Do nothing if Monday between 1:15 pm and 1:45 pm
- condition: time
weekday:
- mon
- condition: time
after: '13:15:00'
- condition: time
before: '13:45:00'
sequence:
- service: script.do_nothing
- conditions:
# Do nothing if Tuesday-Friday between 2:15 pm and 2:45 pm
- condition: time
weekday:
- tue
- wed
- thu
- fri
- condition: time
after: '14:15:00'
- condition: time
before: '14:45:00'
sequence:
default:
- service: switch.turn_on
entity_id: switch.koogeek_power_strip_jumping_spider
- delay: '00:02:00'
- service: switch.turn_off
Instead of using choose with time ranges to “do nothing”, just specify those time ranges in the condition (as logical NOT, meaning not during this time range). That’s where all the filtering belongs.
