Is there a control that you can select a desired time and then send the resulting value via MQTT?
What I am looking for is currently I am using the switch control for my pet hub local project to control the surepetcare connect stack pet doors and feeders. One feature of that is to set the curfew start and stop times.
Ideally it would work exactly like the switch control with a state and set topic but when the user selects it then you have a pop up on a phone or desktop to scroll through the hours and minutes you want to set then press ok. Then HA would send that value via the set topic.
Is there any controls that can do that as I was looking and couldn’t find any.
