This Blueprint gives the kids some control over the online time of their game consoles. They can use buttons to start and pause the online time. Parents can add more time if the kids made their shores. Internet access is controlled via the FritzBox.
Required entities
- 2 datetime (time) helpers for the default time and the additional time the parents can add per klick
- 3 buttons (play, pause and add)
- 1 timer
- 1 fritzbox internet_access switch
The Blueprint
blueprint:
name: Timer based internet access
description: Turn on and off internet access via FritzBox based on a timer
domain: automation
input:
timer:
selector:
entity:
domain: timer
default_time:
selector:
entity:
domain: input_datetime
add_time:
selector:
entity:
add_button:
selector:
entity:
domain: input_button
pause_button:
selector:
entity:
play_button:
selector:
entity:
device:
selector:
entity:
domain: switch
integration: fritz
mode: single
max_exceeded: silent
- platform: state
entity_id: !input add_button
- platform: state
entity_id: !input pause_button
- platform: state
entity_id: !input play_button
- platform: event
event_type: timer.finished
event_data:
entity_id: !input timer
- platform: time
at: "00:00:00"
variables:
input_timer: !input timer
input_default_time: !input default_time
input_add_time: !input add_time
- choose:
- conditions:
- condition: trigger
sequence:
- service: switch.turn_on
entity_id: !input device
- service: timer.start
duration: >
{% set s = states(input_timer) %}
{% set a = state_attr(input_add_time, 'timestamp') %}
{% set d = as_timestamp(strptime("1970-01-01 " + state_attr(input_timer, 'duration') + "-0000", '%Y-%m-%d %H:%M:%S%z', 0)) | int(0) %}
{% set f = 0 if state_attr(input_timer, 'finishes_at') == none else (state_attr(input_timer, 'finishes_at') | as_datetime - now()).total_seconds() | int(0) %}
{% set r = 0 if state_attr(input_timer, 'remaining') == none else strptime("1970-01-01 " + state_attr(input_timer, 'remaining') + "-0000", '%Y-%m-%d %H:%M:%S%z', 0) | as_timestamp | int(0) %}
{% if s == 'idle' and d <= 10 %} {{ a }}
{% elif s == 'idle' %} {{ a + d }}
{% elif s == 'paused' %} {{ r + a }}
{% elif s == 'active' %} {{ f + a }}
{% endif %}
- conditions:
- condition: and
conditions:
sequence:
- service: switch.turn_off
- service: timer.pause
- conditions:
- condition: and
conditions:
- condition: template
value_template: |
{% set d = state_attr(input_timer, 'duration') %}
{{ as_timestamp(strptime('1970-01-01 ' + d, '%Y-%m-%d %H:%M:%S', 0) + timedelta(hours=1)) > 1 }}
- condition: not
conditions:
- condition: state
state: active
sequence:
- conditions:
sequence:
duration: 1
- service: timer.cancel
- conditions:
sequence:
duration: |
{{ states(input_default_time) | string }}
