within my custom componen wattpilot I am trying to add an input entity for time / datetime.
Unfortunately I am not able to find any platform for this and it seems nothing related is documented wihtin Entity | Home Assistant Developer Docs
Additionally I tried to find another component which provides a time/date input entity, but without any success…
Importing from “input_datetime” just causes the following error:
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 335, in async_setup
result = await component.async_setup_entry(hass, self)
AttributeError: module 'homeassistant.components.input_datetime' has no attribute 'async_setup_entry'
Any link to a component creating an input date/time object or to documentation how to do this would be awesome
thanks for the reply.
In meantime I have implemented a service to fulfill the setting of corresponding value.
That’s a first step. - Open topic is now to throw an event if the value is changed from the external system.
Using this combination it will be easy to implement an automation that keeps / syncs my value with an input_datetime object… so the component cannot provide a “ready to go” solution but anything necessary for the users to impement the input themselfes
