Time delay does not work anymore
See follow-up in the reply below, would appreciate if someone can explain why my automation does not work in the new web configuration.
Sometime I converted my automation.yaml file in Home Assistant into the new configuration via the home assistant web interface. A new file automations.yaml was created with IDs for every automation.
One of my automation is that my front door switch turn on in case there is movement in my garden. That works fine ! However it idea is that after 3 minute after the last movement the light switches off. After the conversion the light directly switches of when there is no movement anymore. The configuration in the automisation(s).yaml is exactly the same, but it seems that in the new interface this need to be done different.
What should Í do different ?
The definition on the web interface is :
Trigger Type
state
Entity Id
binary_sensor.voordeur_beweging
From
To
off
For: {
  "minutes": 3
The current automisations.yaml file look like this.
- id: tonfrlght
  alias: Turn on front light when there is movement
    platform: state
    entity_id: binary_sensor.voordeur_beweging
    to: 'on'
  condition:
    condition: state
    entity_id: sun.sun
    state: below_horizon
    service: homeassistant.turn_on
    entity_id: switch.voordeur
- id: tofffrlght
  alias: Turn off front door light 5 minutes after last movement
  - entity_id: binary_sensor.voordeur_beweging
    for:
      minutes: 3
    platform: state
    to: 'off'
  - entity_id: switch.voordeur
    service: homeassistant.turn_off
