The pcb of thumble dryer is gone, so i decided to create a new one using esphome.
Everything is working fine, except my delay script…
If the compressor of the dryer is turned off, i have to wait for 3 minutes to turn on again.
The template switch can be turned on, the gpio must be delayed, even if the microcontroller reboots.
so i decided to use sntp server so make sure.
Sadly something went wrong in the lambda, esp32 reboots, and the difftime isnt working at all.
Here is my code:
globals:
- id: CurrentTIME
type: long int
restore_value: yes
- id: CompressorTimeOFF
type: long int
restore_value: yes
- id: CompressorOFFTime
type: long int
restore_value: no
optimistic: true
restore_state: false
turn_on_action:
- lambda: |-
id(CurrentTIME) = id(sntp_time).now().timestamp;
ESP_LOGI("custom", "Difference in seconds: %l", difftime(id(CurrentTIME), id(CompressorTimeOFF)) ) ;
id(CompressorOFFTime) = difftime(id(CurrentTIME), id(CompressorTimeOFF));
if (id (CompressorOFFTime) > 180) {
ESP_LOGI("custom", "More than 180s elapsed, turning on" );
id(Compressor).turn_on();
} else {
unsigned long TimeDifference = 180-(difftime(id(CurrentTIME), id(CompressorTimeOFF)));
ESP_LOGI("custom", "Waiting for : %l seconds to turn on compressor", TimeDifference ) ;
id(CompressorDelayedTurnOn).execute();
turn_off_action:
- lambda: |-
id(CompressorTimeOFF) = id(sntp_time).now().timestamp;
- switch.turn_off: Compressor
- script.stop: CompressorDelayedTurnOn
icon: mdi:heat-pump
script:
- id: CompressorDelayedTurnOn
mode: single
then:
- delay: !lambda return (180 - difftime(id(CurrentTIME), id(CompressorTimeOFF))) * 1000;
- switch.turn_on: Compressor
