I’m using the newer time node for HA and two input time helpers to tell my pool pump when to turn on and off. When I built it, it tested fine. Node red crashed the other day and my pump hasn’t turned on since. Anyone else run into issue with this node and restarts?
Restarts plural? This is a recurring event? Have you checked your logs?
I just noticed in the debug logs of node red when I published a change it mentions, “this is in the past”. Is it possible it’s grabbing a date even though I’m only using a date time helper configured as time?
A presumption on my part since it hasn’t started the pump in 2 days, since it crashed and restarted.
I believe this is an erroneous error. The newest set of nodes suppresses it. What is the state of your system as far as updates? Were any updates performed around the time that the automation started to fail?
