I have a calender entity with “End time” attribute that contains a date and time value, the value is formated like “2021-08-05 18:00:00”.
I made a sensor that i want to contain one of the folowing values, day, night and change. Day is between 07:00:00 and 18:00:00, night is between 18:00:00 and 07:00:00. The change is 15 minutes before day or night.
This is my sensor
time_of_day:
friendly_name: Time of day
value_template: >-
{% if as_timestamp(state_attr("calendar.aiai", "end_time")) | int < (as_timestamp(now()) | int -15*60)-%}
Passbyte
{% elif as_timestamp(state_attr("calendar.aiai", "end_time")) | timestamp_custom('%H') | int < 17 -%}
Nattpass
{%- elif as_timestamp(state_attr("calendar.aiai", "end_time")) | timestamp_custom('%H') | int > 6 -%}
Dagpass
{%- endif %}
I get the day and night values correctly but I never get the change value.
{% if as_timestamp(state_attr('calendar.aiai', 'end_time')) | int -15*60 < (as_timestamp(now()) | int ) and as_timestamp(now()) < as_timestamp(state_attr('calendar.aiai', 'end_time')) or (as_timestamp(now()) | int ) < as_timestamp(state_attr('calendar.aiai', 'end_time')) | int +5*60 and (as_timestamp(now()) | int ) > as_timestamp(state_attr('calendar.aiai', 'end_time')) -%}
It is. How ever the tricky part is that when current even a new one is started. For example, current events end time is 2021-08-06 07:00:00. Next event start at 2021-08-06 07:00:01.
The use of the now() function within a template means that the template will be evaluated every minute on the minute (and not every second).
Therefore the template will not be evaluated at 07:00:01 but only at 07:00:00, 07:01:00, 07:02:00, etc. In other words, the template’s ‘resolution’ is per minute and not per second.
