I have a HeimVision A80S. I desoldered the esp on it and soldered a classic ESp-8266 chip. I programmed it with the code from
Most of the entities worked good. I did modify a couple of entities who where not properly working.
I never got the time component working properly. Below my code:
time:
- platform: sntp
timezone: "America/Montreal"
tuya:
time_id: sntp_time
on_datapoint_update:
- sensor_datapoint: 127
datapoint_type: raw
then:
- lambda: |-
ESP_LOGD("tuya", "on_datapoint_update %s", hexencode(x).c_str());
I don’t understand what ESP_LOGD does exactly and how it works. The Time doesn’t change on the display. Below some datapoint who look interesting:
[18:52:22][C][tuya:054]: Datapoint 107: raw (value: 19.01)
[18:52:23][C][tuya:054]: Datapoint 127: raw (value: 00.02.D0.7F.0F.01.01.0A.01.0A.0A.00.00.02.D0.7F.0F.01.01.0A.01.0A.0A.00.00.02.D0.7F.0F.01.01.0A.01.0A.0A.00.00.02.D0.7F.0F.01.01.0A.01.0A.0A.00 (48))
[18:52:23][C][tuya:054]: Datapoint 128: raw (value: 00.01.01.0A.1E.01.1E.0F.1E.01 (10))
The datapoint 107 is used to change the radio post (and changing the radio works well) so I wonder if maybe the code to send the time isn’t right or maybe it’s a different datapoint to store the time on the system ?? Please be aware that I have tryed changing 127 by 107 and 128 as well. Nothing works.
I would need some help please.
Thanks a lot!
