Mon Apr 08 2019 12:59:09 GMT-0700 (Pacific Daylight Time)
Error doing job: Exception in callback async_track_utc_time_change..pattern_time_change_listener() at /srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/event.py:359
File “/usr/lib/python3.5/asyncio/events.py”, line 126, in _run
self._callback(*self._args)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/event.py”, line 368, in pattern_time_change_listener
calculate_next(now)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/event.py”, line 353, in calculate_next
matching_hours)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/util/dt.py”, line 256, in find_next_time_expression_time
raise ValueError("Cannot find a next time: Time expression never "
ValueError: Cannot find a next time: Time expression never matches!
ive tried everything that i could find on this forum as well as setting a sensor for time, not sure if that is even necessary, also the timezone is set in the configuration…
- id: '0000000000000000' alias: pump recirculate 30 seconds trigger: - hours: '2' platform: time_pattern seconds: '' condition: [] action: - data: message: pump triggered service: notify.gmail - data: entity_id: switch.pump service: switch.turn_on - delay: 00:00:30 - data: entity_id: switch.pump service: switch.turn_off
