I have a Hassio running inside a VM (managed by VirtualBox). I created a time_pattern to run automation every minute:
- platform: time_pattern
minutes: /1
but it gets executed every 2-3 minutes.
#### January 23, 2021
Has been triggered by time pattern 8:34:56 PM - 22 seconds ago
Has been triggered by time pattern 8:32:41 PM - 3 minutes ago
Has been triggered by time pattern 8:30:39 PM - 5 minutes ago
Has been triggered by time pattern 8:28:05 PM - 7 minutes ago
Any ideas what is going on? Load inside the VM is below 0.5 and memory is at 75% free capacity.
I checked both, but it doesn’t matter since the UI is only GUI to edit the yaml configuration. IMO both minutes: /1 as well hours: * minutes: * seconds: 0 should have the same effect. I also noticed that inject and cronplus nodes in node red are affected as well.
