This is a bit long but there is a lot of detail here so please stay with me.
I wrote code in yaml to fire every 30 minutes to evaluate the quality of the daylight outside and then update a sensor to reflect the results. The time pattern did not fire at all but when clicking on the automation and running manually, everything worked as designed.
- id: "House - Update Daylight Status"
alias: "House - Update Daylight Status"
description: "House - Update Daylight Status"
triggers:
- trigger: time_pattern
minutes: "/5"
conditions:
- "{{ is_state('input_boolean.house_auto_mode', 'on') }}"
- "{{ is_state('input_boolean.house_auto_outside', 'on') }}"
- "{{ is_state('input_select.house_status_dropdown', not 'Vacation') }}"
- condition:
- or:
# - "{{ states('weather.great_ecobee', 'condition') == 'partlycloudy' }}"
- "{{ states('weather.great_ecobee', 'condition') == 'cloudy' }}"
- "{{ states('weather.forecast_home', 'cloud_coverage') | int(0) > 78}}"
- "{{ states('sun.sun', 'below_horizon')}}"
actions:
- action: input_select.select_option
entity_id: input_select.daylight_status
option: Dark
mode: single
I then thought that since I already had one automation that was working with time_pattern, I would go back and change the automation to the old way - replacing trigger with platform and actions with action. The exact same script also did not trigger automatically (every 5 mins in this example) but also worked when ran manually.
Finally, I broke down and went to the UI (I know, don’t hate me
)_
The UI wrote the code in what I feel is more verbose way but what the hell, had it had worked, I would have been fine with it, but it also did not fire automatically! However, when I ran it manually, it ran fine. The UI automation below:
- id: "1734547033948"
alias: House test Every 30
description: HTest Every 30
triggers:
minutes: "/5"
conditions:
- condition: state
entity_id: input_boolean.house_auto_mode
state: "on"
- condition: state
entity_id: input_boolean.house_auto_outside
state: "on"
- condition: state
entity_id: input_select.house_status_dropdown
state: not 'Vacation'
- condition: or
conditions:
- condition: state
entity_id: weather.great_ecobee
state: cloudy
- condition: state
entity_id: weather.forecast_home
state: cloudy
- condition: state
entity_id: sun.sun
state: below_horizon
actions:
option: Dark
mode: single
So now I have three different automatons that work when run manually but will not fire every X mins. In fact, to be clear, they do not fire at all unless manually told to do so.
System Info:
- Core2024.12.4
- Supervisor2024.12.0
- Operating System14.1
- Frontend20241127.8
The other automation that runs fine starts like the below:
- id: "House - Auto Set Sleep"
alias: "House - Auto Set Sleep"
description: "House - Auto Set Sleep"
triggers:
- trigger: time
at: "22:30:00"
minutes: "/10"
condition:
I know this worked as of last Sunday as I hosted a party and the shutdown did not happen until 1:30AM which means, it was the time_pattern part of the automation that handled the shutdown as it was was past 22:30.
I have spent a lot of time on this and do not understand why a simple time pattern will not fire when told to do so. Any help will be most appreciated. This is a relatively new install from a few months ago so it is not like it has been running for years like some of my previous installations which underwent many upgrades. This is clean.
Many thanks
Craig
