Time_pattern throwing an error
Getting an error in my logs with
  - id: Set_Indicator_Red
    alias: 'Set indicator red'
    - platform: time_pattern
      seconds: '/30'
    condition:
      - condition: state
        entity_id: switch.red_light
        state: 'on'
      - condition: state
        entity_id: switch.red_indicator
        state: 'off'
      - service: switch.turn_on
the above throws an error and that automation never ‘loads’, but the below doesn’t and the automation is there in developer view ?
Invalid config for [automation]: must be a value between 0 and 59 for dictionary value @ data[‘seconds’]. Got None. (See ?, line ?).
  - id: RED_ON_repeat
    alias: 'RED ON repeat'
      seconds: '/59'
    condition:
      - condition: state
        state: 'on'
      - condition: template
        value_template: "{{ (as_timestamp(now()) - as_timestamp((states.switch.red_light.last_updated)) > 119 )}}"
      - service: mqtt.publish
          topic: "iotlink/all/commands/run"
Are you sure it is that trigger and not another one?
