When launched manually, and all conditions are being met, this automation give me the expected result. However I would very much like to trigger this on regular basis, but somehow I can not make that happen. Anyone who can help me spot my mistake?
When triggered manually the conditions are skipped. One of your conditions is preventing execution of the actions when the time pattern triggers. Use the automation trace to work out which one:
There are better ways of doing this than checking every 15 minutes. I’ll update my post with a suggestion soon.
There is no reason why that automation should be based on a time trigger.
Make one of them (or all three) the trigger and condition instead and it will be much better
thanks guys, I was not aware that conditions are skipped when running manually so I guess that explains this behaviour. I’ll troubleshoot my automation further with this in mind.
However should I not have seen in the HA logs that the automation has tried to run every 15 mins? I can not see any evidence anywhere that it has even tried to execute?
(And yes, I knew as well there are other ways of achieving this but wanted to better understand the time pattern trigger. Sorry for not mentioning this…)
