Time sensor and automation
I’ve been really struggling to fix something I believe is simple, I must be missing something.
I have a template sensor that I want to use for multiple automation:
- template:
  - sensor:
    - name: wake_up_time
      state: >
        {%if states('binary_sensor.today_is_workday') == 'off' -%}
          {{ (states('input_datetime.holidays_wake_up_time')) }}
        {%- elif states('input_boolean.school_holidays') == 'on' -%}
            {{ (states('input_datetime.school_holiday_wake_up_time')) }}
        {%- else -%}
            {{ (states('input_datetime.default_wake_up_time')) }}
        {%- endif %}
      icon: "mdi:clock"
this sensor looks ok when I check his state with the developer template tool:
{{ states('sensor.wake_up_time')  }}  =>   wake_up_time  18:53:00
however my automation
- alias: "Parents wake up"
  condition:
    - condition: state
      entity_id: input_boolean.automation
      state: "on"
    - platform: time
      at: sensor.wake_up_time
    - service: homeassistant.turn_on
      entity_id:
        - switch.curtains_master
        - switch.curtains_living
is never triggered…what am I missing??
Thanks in advance
Add device_class: timestamp to your template sensor.
https://www.home-assistant.io/docs/automation/trigger/#sensors-of-datetime-device-class
thanks for your answer, but I m afraid it still not working
- template:
  - sensor:
      state: >
        {%- else -%}
        {%- endif %}
      icon: "mdi:clock"
Interestingly the template editor shows now :
unknown
would you have an ideaof anything else missing?
If you add this to a Template Sensor:
then the value produced by the Template Sensor should include time and date in ISO format. For example:
- template:
  - sensor:
      state: >
          {{ today_at(states('input_datetime.holidays_wake_up_time')).isoformat() }}
            {{ today_at(states('input_datetime.school_holiday_wake_up_time')).isoformat() }}
        {%- else -%}
            {{ today_at(states('input_datetime.default_wake_up_time')).isoformat() }}
        {%- endif %}
      icon: "mdi:clock"
Alternative:
- template:
  - sensor:
      state: >
        {% if is_state('binary_sensor.today_is_workday', 'off') -%}
          {% set t = 'holidays_wake_up_time' %}
        {%- elif is_state('input_boolean.school_holidays', 'on') -%}
          {% set t = 'school_holiday_wake_up_time' %}
        {%- else -%}
          {% set t = 'default_wake_up_time' %}
        {%- endif %}
        {{ today_at(states('input_datetime.' ~ t)).isoformat() }}
      icon: "mdi:clock"
Thank you very much, indeed adding the
today_at(
make my sensor a valid time sensor, and my automation worked!.. The first day …
But the date of the sensor stays at the date of the last update, so if I don’t change my input_datetime, the next day , wake_up_time is if set to previous day and the automation is not trigger.
I guess an event “the date has changed” should update it, but looks like today_at is not triggering it…
Any idea please? ( And thanks for the help so far)
A Template Sensor’s template is updated whenever one of the entities referenced in the template changes state. If none of the entities change state, the template is not updated.
I suggest you create a Trigger-based Template Sensor like this:
- template:
    - trigger:
        - platform: time
          at: '00:00:01'
        - platform: state
          entity_id:
            - binary_sensor.today_is_workday
            - input_datetime.holidays_wake_up_time
            - input_boolean.school_holidays
            - input_datetime.default_wake_up_time
          state: >
            {%- else -%}
            {%- endif %}
          icon: "mdi:clock"
It will update at the start of every day and when any of the entities changes state.
Thank you so much for the detailed explanation, works perfectly!
