Time templates
Might it be an idea to introduce time schedule templates? Or there must already be a way I can’t find of course…
The idea is to have time templates with start/end time on certain days which you then can select in the automation window, so you can use the same day/time schedules for multiple automations.
Regards
Richard
Well you can use all the time templating tools in a template trigger.
https://www.home-assistant.io/docs/automation/trigger/#template-trigger
https://www.home-assistant.io/docs/configuration/templating/#time
Or did you mean something like this?
https://community.home-assistant.io/t/scheduler-card-custom-component/217458
