I am working on a project where I want to use several inputs from Home Assistant using ESPHome and custom C++ code via an external file. The project is a wordclock, which I now have working on via Arduino, but it’s rather static. All code runs on the Arduino, and I am trying to change this to an ESP32 with connection to ESPHome/HA.
So far I have been able to add several components (2 input numbers, and 1 boolean), but I am really struggling getting anything time-related to pass to the code.
The YAML file contains the following:
esphome:
platform: ESP32
board: esp32doit-devkit-v1
includes:
- wordclock/wordclock.h
libraries:
- Wire
- SPI
- adafruit/Adafruit BusIO @ ^1.14.1
- adafruit/Adafruit GFX Library @ ^1.11.3
- adafruit/Adafruit NeoPixel @ ^1.10.6
- adafruit/Adafruit NeoMatrix @ ^1.3.0
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "code..."
ota:
password: "password..."
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Wordclock Fallback Hotspot"
password: "h6NtbR90xUJ2"
captive_portal:
time:
- platform: homeassistant
number:
optimistic: true
min_value: 1
max_value: 100
step: 1
restore_value: true
optimistic: true
min_value: 1
max_value: 255
step: 1
restore_value: true
switch:
optimistic: true
restore_state: true
custom_component:
- lambda: |-
auto myComponent = new AdvancedBlinkComponent(id(blink_enable), id(blink_frequency), id(blink_brightness), id(blink_time).now().hour);
return {myComponent};
my wordclock/wordclock.h file contains this:
#include "esphome.h"
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#include <Adafruit_NeoPixel.h>
#define LED_PIN 2
#define PIN 15
#define NUMPIXELS 16 // Popular NeoPixel ring size
#define MATRIXWIDTH 16 // Popular NeoPixel ring size
#define MATRIXHEIGHT 16 // Popular NeoPixel ring size
//Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(MATRIXWIDTH, MATRIXHEIGHT, PIN,
NEO_MATRIX_BOTTOM + NEO_MATRIX_RIGHT +
NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
class AdvancedBlinkComponent : public Component
public:
unsigned long last_led_change;
bool enable = false;
float frequency = 1;
float brightness = 0;
int hour = 0;
AdvancedBlinkComponent( esphome::template_::TemplateSwitch *&_enable,
esphome::template_::TemplateNumber *&_frequency,
esphome::template_::TemplateNumber *&_brightness,
esphome::template_::TemplateNumber *&_timetest)
_enable->add_on_state_callback([this](bool newState)
{ enable = newState; });
_frequency->add_on_state_callback([this](float newFrequency)
{ frequency = newFrequency; });
_brightness->add_on_state_callback([this](float newBrightness)
{ brightness = newBrightness; });
_timetest->add_on_state_callback([this](int newHour)
{ hour = newHour; });
void setup() override
pinMode(LED_PIN, OUTPUT);
last_led_change = millis();
matrix.begin(); // INITIALIZE NeoMatrix object (REQUIRED)
matrix.setBrightness(40);
matrix.fillScreen(0);
matrix.show();
void loop() override
if (enable == false)
matrix.show();
return;
unsigned long now = millis();
if (last_led_change + 1000 / frequency < now)
digitalWrite(LED_PIN, !digitalRead(LED_PIN));
last_led_change = now;
// NEOMATRIX
matrix.setBrightness(brightness);
matrix.drawPixel(0, 0, matrix.Color(0, 0, 255));
if (digitalRead(LED_PIN) == 1) {
matrix.setTextColor(matrix.Color(255, 0, 0));
matrix.setCursor(2, 0);
matrix.print(F("12"));
else {
matrix.setTextColor(matrix.Color(0, 128, 128));
matrix.setCursor(2, 9);
matrix.print(F("48"));
matrix.show();
While trying to compile the code I get the following error:
error: invalid conversion from 'uint8_t {aka unsigned char}' to 'esphome::template_::TemplateNumber*' [-fpermissive]
I believe the issues lies within the wordclock.h code, but I am not sure. I have tried to use several different ways of passing the ‘hour’ value of the homeassistant_time, but I keep getting errors like this.
The fact that the 3 other values pass fine (enable, frequency, brightness) but the hour-value doesn’t, makes my head spin.
ps. I am not a c++ developer, but have so far been able to get the wordclock working via the Arduino IDE. So I have a feeling that this issue is specific to the ESPHome part of things?
In the end I use multiple parts of the time-logic, so I am not sure if it would make sense to pass the year, month, day, hour and minute separately, or to pass the timestamp and then do the split logic in my wordclock.h file. Either way, I guess if I get at least one of them working, then that example would make me able to add the rest too.
