Time trigger in automation.yaml now longer working after upgrade
I upgraded from 0.41 to 0.51 yesterday unfortunately my log file now gives me the following error and none of my automations work:
ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [after] is an invalid option for [automation]. Check: automation->trigger->0->after. (See /home/homeassistant/.homeassistant/configuration.yaml, line 126).
The line number is wrong as my automation.yaml only has a few lines in, nowhere near 126! Anyway, here is my automation that worked fine with version 0.41:
- alias: '#1 - Turn on at 15:30 on weekdays'
    platform: time
    after: '15:30:00'
  condition:
  - condition: time
    weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
    - service: climate.set_temperature
      data_template:
        entity_id: climate.thermostat1
        temperature: '{{ states.input_slider.desired_temp_occupied.state }}'
        operation_mode: Heat
Could someone tell me why [after] is now an invalid option and what to replace it with?
Change “after” to “at”
Works perfectly now, thanks very much for your super-quick response :slight_smile:
#breakingchange: https://github.com/home-assistant/home-assistant/pull/7866
It’s a breaking change introduced in version 0.46
Automation - time: The after keyword for time triggers (not conditions) has been deprecated in favor of the at keyword. This resembles better what it does (old one still works, gives a warning) (@armills - #7846) (automation.time docs) (breaking change)
Automation - numeric_state: above and below will no longer trigger if it is equal. (@armills - #7857) (breaking change)
Broadlink switches: Entity ids will change for switches that don’t have a default name set. In this case the object_id is now used. (@abmantis - #7845) (switch.broadlink docs) (breaking change)
Disallow ambiguous color descriptors in the light.turn_on schema. This means that you can no longer specify both xy_color and rgb_color. (@amelchio - #7765) (breaking change)
