Assistance please with figuring out why some time triggers work and some do not.
Below is an example trigger I made yesterday, that did not fire today.
- id: '1603417395684'
alias: Buggery_01
description: ''
- platform: time
at: 05:51:00
condition:
- condition: state
entity_id: binary_sensor.workday_sensor
state: 'On'
- scene: scene.wakeup_01
mode: parallel
max: 10
In the example docs, it lists a quote. The built in automation editor does not input a quote.
HA Trigger Docs
Other online examples from the forums show a single tick ’ ; This does not reliably help either.
Curiously enough I have other automations that work just fine. I have one that turns on a particular light 15 minutes prior to sundown that works, and if the sun is up for longer days, I have another automation that kicks the light on at ‘18:45:00’ …single tick, and it triggers just fine.
Can somebody explain to me why the editor doesn’t put in any quotes or ticks, manually putting in a tick works on some but not others, and why manually editing in quotes or ticks doesn’t seem to make any difference? The same triggers happen or don’t happen. I just made the examples shown above, 1 minute off the originals, just to see if manually creating a similar one would trigger ok.
Automations are on. States are on. system has been rebooted and rebuilt, check configs say the configs are fine, I am just really at a loss.
Begging for any assistance. I’ve searched, tried everything I could find, and rebuilt the server several times.
