packages: !include_dir_named packages
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: #<= your x number
longitude: #<= your y number
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: # <= how tall you are
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Pacific/Auckland
# Customization file
customize: !include customize.yaml
and if you dont use the “configuration.yaml”
you have to move the marker manully to your location
Thank you! Manually adding the long/lat to the config file solved the problem. I wasn’t able to manually move the marker on the map. Maybe a UI suggestion should be to add the longitude and latitude fields to the Config UI similar to elevation to make it easier to modify if the map interaction doesn’t work.
