I’m using MariaDB as my DB for HA and it works fine. However when I now try to use the data it appears all timestamps are stored in UTC. In other databases I have other data (hourly prices for example) that are in local time. In order to match (join) them I need to handle different time zones in MariaDB and in order to do that I’v found out I need to run a script that loads the time zone data from some sort of Linux files. https://mariadb.com/kb/en/mysql_tzinfo_to_sql/. So… Then my question is… how do I get into some shell for MariaDB in a container on HA?
Thanks for any pointers…
OK, managed to figure this out. As I couldn’t find info on this I thought I’d just share the solution here
- Start an SSH session to your HA. I use the SSH & Web Terminal Add-on from the add-on-store.
- Run:
sudo docker ps --format "table {{.ID}}\t{{.Names}}"
to get the container name. My guess is that the container is default addon_core_mariadb
- Start a bash session for the container
docker exec -it addon_core_mariadb /bin/bash
- Run the MariaDB script to populate the time zone tables
mysql_tzinfo_to_sql /usr/share/zoneinfo | mysql -u root mysql
- Be patient, this took some time for me on my Pi4…
- Once you get the prompt back you should now see your time zone tables populated and you should be able to start converting between time zones.
